I have a problem; I tried to give the Sonof an ip-address but than i made a type-o and forgot the ip range...
I could not reach it anymore, i have flashed the firmware again but it remembers settings and it wont show up as new esp device on the wifi-list.. How do i completely reset the flash memory?
Flash and stil remembers old settings
Re: Flash and stil remembers old settings
Two common choices if you can't connect to the web interface:
1. Disconnect power. Use a jumper wire and connect RX and TX together. Apply power and wait a few seconds; During boot the flash will be erased. Then power down, remove jumper.
2. Connect the serial port to your PC. Send a Reset command using a serial terminal program. https://www.letscontrolit.com/wiki/inde ... _Reference
Hi Thomas.
Thanx im gonna try your tips asap
Best regards Karel
Best regards Karel
Third option, flash a blank bin and then the real bin.
Users browsing this forum: No registered users and 115 guests
