when I use a classic swith with a gpio, for example:
Jus: Ampoule and GPIO: GPIO12
For ON: gpio,12,1
For Off: gpio,12,0
To use in rule: if [Jus#Ampoule] = 1
If I have no more GPIO available, and I want to use the switch name directly, I do not know how to change the state:
Jus:Ampoule and GPIO: None
For ON: ?????????
For Off: ?????????
Can you help me ?
Thank you
switch without gpio
switch without gpio
Sigalou
Utilisateur/Développeur Plugin Jeedom
Créateur des plugins Alexa-API & WatchDog
- Site perso dédié domotique : Sigalou-domotique
- Support : Alexa-API WatchDog
- Documentation, Changelog et Todo-List : Alexa-API WatchDog
- budman1758
Re: switch without gpio
I don't know of a way to change the state of a GPIO that does not exist.
Maybe try using a dummy device to change values with rules?
Are you talking about inputs or outputs?
Switch inputs are limited as an input needs a task - tasks are limited to 12.
Up to 12 inputs can be used with two PCF8574 or one MCP23017
(8 port and 16 port IO expanders)
Outputs are not limited by tasks as they don't need a task at all, they are just
driven by a command.
You can stack up to 8 MCP23017 by setting different addresses.
This gives 8 x 16 = 128 outputs.
Yes, that's it, I need a dummy device.budman1758 wrote: ↑12 Sep 2019, 18:36 I don't know of a way to change the state of a GPIO that does not exist.
I have no more GPIO available (it's on sonoff4chpro, so the gpio are taken by relays and buttons)
Sigalou
Users browsing this forum: Google [Bot] and 124 guests
