4x20 LCD, how to do not display decimals
mackowiakp
#1 Post by mackowiakp » 14 Sep 2019, 08:13
To limit the number of displayed (and not always needed) characters on a 4x20 LCD, It would be needed to be able to display some numbers without a decimals. Or with only one decimal place. For example, when displaying atmospheric pressure, no decimals display is needed. Similarly, when showing the temperature, one decimal place is enough.
I query Domoticz SQLite DB for necessary parameters and then send it to quad dummy sensor in nodeMCU using LUA script. This script cut off for example decimals in value of atmospheric pressure and send it in this form to nodeMCU equipped with 4x20 LCD. That implicates event:
EVENT: Temp-Baro#Baro=1036.00
As You can see, [Temp-Baro#Baro] variable has two zeros as decimals. But I want to display it on 2x4 LCD without decimals. Is it possible? If yes, how can I do it?
Re: 4x20 LCD, how to do not display decimals
#2 Post by grovkillen » 14 Sep 2019, 09:01
Set the number of decimals in the task setting...
mackowiakp
#3 Post by mackowiakp » 14 Sep 2019, 09:21
I already have „zero” decimals in sensor value definition
#4 Post by grovkillen » 14 Sep 2019, 09:26
And it still display those decimals on the display? If so, what version are you on?
mackowiakp
#5 Post by mackowiakp » 14 Sep 2019, 10:38
Yes, it still display decimals. Build mega-20190827 (normal). But remember that there is still dummy sensor issue with dummy sensor, listed in GitHub. I dont know for sure, but maybe it is related to this issue too?
#6 Post by grovkillen » 14 Sep 2019, 11:01
If you change to three decimals, as a test, what happens?
PS. The log might not obey to the decimal setting, it's up to the plugin to decide that.
mackowiakp
#7 Post by mackowiakp » 14 Sep 2019, 11:14
OK. I will do several tests, including directly with %eventvalue% and post again.
mackowiakp
#8 Post by mackowiakp » 14 Sep 2019, 11:31
Its crazy.... After power on/off it started work properly. Formerly I rebooted device from "Tools" menu and it still displayed wrong number of decimals. Now temperature has on decimal position and pressure no decimals. Correct ! THX for Your support !
#9 Post by grovkillen » 14 Sep 2019, 11:33
Good to hear. Sometimes a real power cycle is needed.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 109 guests
