mini dashboard reload
ingoiot
#1 Post by ingoiot » 19 Sep 2019, 23:11
hi,
is there an option to reload the value of a sensor like [ds18b20#Temperature]
automatically without reloading the whole page?
Re: mini dashboard reload
#2 Post by grovkillen » 20 Sep 2019, 07:59
Yes you can by using JavaScript
ingoiot
#3 Post by ingoiot » 20 Sep 2019, 11:58
i´ve tried some code, but somehow it doesnt work:
<br><br>
<H3>DISTANZ:</h3>
<br onload="meineFunktion()">
<script>
function meineFunktion()
setInterval(document.write("[s04#Distance]"), 1000);
</script>
<br>
</HTML>
the following code shows the value twice in the code inspector
(once on the site itself)
but i dont understand why the value shows two times in this example,
and why document.write displays nothing.
(inpector db3pic.png)
<br><br>
<H3>DISTANZ:</h3>
<br>
<script>
document.write("[s04#Distance]");
</script>
<br>
</HTML>
#4 Post by grovkillen » 20 Sep 2019, 12:15
You need to fetch the data from the /JSON endpoint.
ingoiot
#5 Post by ingoiot » 20 Sep 2019, 18:06
tnx,
i'll try that.
does it make a performance or memory difference using
<espeasyip>/json
or only
<espeasyip>/json?tasknr=<tasknumber>&view=sensorupdate
#6 Post by grovkillen » 20 Sep 2019, 18:09
No you need to fetch it. You can study the device page how I do the fetch.
#7 Post by TD-er » 20 Sep 2019, 18:42
Please do not query the json url too often. It will cause a queue in the ESP which will eventually crash.
Continuous F5 in the browser is a good way to crash the ESP.
So I would say, don't go below 1x per sec.
There is also a suggested time to retry in the JSON as used on the device tab to refresh the values.
This suggested retry time is the expected time a new value will be present.
ingoiot
#8 Post by ingoiot » 09 Oct 2019, 18:48
i tried to fetch it this way:
const response1 = await fetch('http://192.168.3.10/json');
const myJson1 = await response1.json();
console.log(JSON.stringify(myJson1));
but firefox tells me:
"Content Security Policy: The page's settings blocked the loading of a recource http....
is this set in espeasy?
#9 Post by TD-er » 09 Oct 2019, 22:07
Hmm, that looks like a cross-site scripting protection.
As far as I know, we do set a flag which allows the JSON URL's to be used in cross-site scripts.
Or it could be your browser does not accept mixed content from HTTPS and HTTP url's?
ingoiot
#10 Post by ingoiot » 11 Oct 2019, 18:33
tnx,
looks like it was a Problem with the Browser - on an other computer it works.
now i have a little Problem with my code maybe someone can point me in the right direction.
I think it might have something to do with scope, but im not sure.
code part:
<head>
    <script>
        object.onload = function tempSet() {
            const response = await fetch("/json?view=sensorupdate");
            const myJson = await response.json();
            let tempVar = myJson.Sensors[5].TaskValues[0].Value;
            document.getElementById("tempId").innerHtml = tempVar;
    </script>
</head>
<body>
    <h1 style="color:Red; font-size:30px;">Temperaturen</h1>
    <div style="overflow-x:auto;">
        <table>
            <tr>
                <th>Temperatur 1</th>
                <th id="tempId">Temperatur 1wert</th>
            </tr>
        </table>
    </div>
</body>
whole file:
<meta name="viewport" content="width=width=device-width, initial-scale=1">
<STYLE>
        font-family: sans-serif;
        font-size: 16pt;
    .button {
        margin: 4px;
        padding: 4px 16px;
        background-color: #07D;
        color: #FFF;
        text-decoration: none;
        border-radius: 4px
</STYLE>
</HTML>
<style>
    table {
        border-collapse: collapse;
        width: 100%;
    th,
    td,
    h1 {
        text-align: center;
        padding: 8px;
    tr:nth-child(even) {
        background-color: #f2f2f2;
</style>
<head>
    <script>
    </script>
</head>
<body>
        <table>
            <tr>
            </tr>
        </table>
    </div>
</body>
</html>
</body>
</html>
ingoiot
#11 Post by ingoiot » 13 Oct 2019, 11:42
i just optimized the code a little, and noticed that when i view the source code in the browser,
the square brackets of the array are cut off, and the console shows variable not declared. Why is that?
<head>
    <script>
       window.addEventListener("load", () => {
            let tempVar = myJson.Sensors[3].TaskValues[0].Value;
            document.getElementById("tempId").innerHTML = tempVar;
    </script>
</head>
<head>
<script>
let tempVar = myJson.Sensors.TaskValues.Value;
</script>
</head>
#12 Post by TD-er » 13 Oct 2019, 20:41
The only reason I can think of right now is that the script may be sent through the template replacement routines to be able to have some system variables replaced in the source.
But it should only replace the things it can replace and not remove the [] from the code when it cannot replace parts.
Nestitherapy
#13 Post by Nestitherapy » 14 Oct 2019, 08:15
You should fetch and check the display page on how to fetch it.
ingoiot
#14 Post by ingoiot » 15 Oct 2019, 20:43
i think im doing pretty much exact that.
when i save the file as .html the browser shows the sqaure brackets where they should be,
but unfortunately the site is shown as plain text, no idea why.
#15 Post by TD-er » 15 Oct 2019, 21:59
Rename the file to .htm (without the L)
ingoiot
#16 Post by ingoiot » 15 Oct 2019, 22:58
man - that was just too easy :(..
now the source code looks good, but the console throws
SyntaxError: await is only valid in async functions and async generators
at me.
when i insert this to the console:
it does exactly what i want.
i just dont understand why and where async should be needed when i use this:
#17 Post by TD-er » 16 Oct 2019, 02:10
Well I don't speak JavaScript, especially not at this hour :)
But I can imagine await is needed to have some callback on a function which does return immediately but does its task in the background and at finish calls your await'ed function.
I've heard people talk about 'promises' in JavaScript, so maybe that's a good Google term for looking into this?
So given the warning you get, I would say the await does actually do nothing in your case, since the function before it will only return when the task was done.
ingoiot
#18 Post by ingoiot » 16 Oct 2019, 20:36
got it! (i think)
if someone is interested:
<!DOCTYPE html>
<html>
<STYLE>
        font-size: 16pt;
    .button {
        margin: 4px;
        padding: 4px 16px;
        color: #FFF;
        border-radius: 4px
    table {
        width: 100%;
    th,
    td,
    h1 {
        text-align: center;
        padding: 8px;
        background-color: #f200f2;
</style>
<head>
    <script onload="setInterval()">
 setInterval (async function() {
            tempVar = myJson.Sensors[1].TaskValues[0].Value;
        },1000);
    </script>
</head>
<body>
        <table>
            <tr>
            </tr>
        </table>
    </div>
#19 Post by grovkillen » 16 Oct 2019, 21:09
Yes that works but it will fetch the value once every second even if you have the interval of the sensor set to once per 10, 30 or 60 seconds.
ingoiot
#20 Post by ingoiot » 16 Oct 2019, 22:39
man - and i thought i was done^^
        var tempVarInterval = 1000;
        setInterval(async function () {
            tempVarInterval = myJson.Sensors[1].TaskInterval;
        }, tempVarInterval);
    </script>
seems to fix this.
#21 Post by TD-er » 17 Oct 2019, 00:58
The suggested interval is also given in the JSON as a TTL value.
You can have a look at the JavaScript made by Grovkillen in the Device tab page.
ingoiot
#22 Post by ingoiot » 17 Oct 2019, 19:02
i dont quite grasp the utility of "suggested interval"
(does TTL mean time to live?).
is there any difference between using TTL and TaskInterval?
#23 Post by grovkillen » 17 Oct 2019, 19:52
Since you're only interested in one value you can use the individual interval. But if you want to get ALL the values you should use the TTL since that one is suggesting when the next value will be updated.
#24 Post by TD-er » 17 Oct 2019, 23:04
The TTL value is more dynamic and indeed based on all tasks.
It is roughly -what Grovkillen also said- an indicator when to expect a new value.
Still, if the "interval timer" of all plugins is set to the default 60 seconds, then it will take roughly 30 seconds on average before you'll see a switch value being updated after pressing the button.
Users browsing this forum: Google [Bot] and 19 guests
