paltformio.ini error
mackowiakp
#1 Post by mackowiakp » 17 Oct 2019, 15:49
I try to compile mega-20190928 (Linux, VS) but I got such error:
> Executing task: platformio run --environment normal_core_260_sdk222_alpha_ESP8266_4M1M <
Error: Invalid '/home/maciek/TMP/ESPEasy_mega-20190928/source/platformio.ini' (project configuration file): 'While reading from '/home/maciek/TMP/ESPEasy_mega-20190928/source/platformio.ini' [line 501]: section 'env:esp32test_1M8_partition' already exists'
The terminal process terminated with exit code: 1
There was M$ update of VS, maybe thats the reason?
Re: paltformio.ini error
#2 Post by TD-er » 17 Oct 2019, 15:54
Well it is a known issue, you can remove the duplicate env part from platformio.ini
But you may run into another issue if you have Python 3.8 installed.
See: https://github.com/platformio/platformi ... ssues/2796
mackowiakp
#3 Post by mackowiakp » 17 Oct 2019, 16:23
I use Python 2.7. After removing env part from platformio.ini, works OK. THX
