ESP8266-01 Manufacturer: 5E Do Not Flash
jchiantera
#1 Post by jchiantera » 06 Nov 2019, 03:26
HI good nights everybody
I flash several ESP8266-01 from different manufacturers or flash Vendor until now all flash without problem, but the flash vendor: 5Eh do not flash.
Any have an Idea whats is wrong or what I doing wrong
Thanks for help
Jose
Flying Domotic
Re: ESP8266-01 Manufacturer: 5E Do Not Flash
#2 Post by Flying Domotic » 06 Nov 2019, 10:19
Did you tried "DOUT" flash mode?
#3 Post by TD-er » 06 Nov 2019, 11:12
Have you also tried flashing it with the esptool.py?
jchiantera
#4 Post by jchiantera » 06 Nov 2019, 15:23
Thanks for answer.
Before this problem I flash all ESP8266-01 with DOUT arduino IDE
Now I try DOUT, DIO, QOUT and QIO with arduino IDE
and esptool esptool.py v2.8-dev
with no result
#5 Post by TD-er » 07 Nov 2019, 12:44
If even those other tools cannot flash it, maybe it should (also) be reported within the esptool repo?
It could be the flash chip does need other parameters to flash it, but that's not the part of libraries we control, sadly.
Can you change the flash frequency in ArduinoIDE (or at the other flash tools) ?
