(solved)rule and event within rule syntax
riker1
#1 Post by riker1 » 13 Nov 2019, 17:57
New doku linked:
https://espeasy.readthedocs.io/en/lates ... Rules.html
I am consued as I do see different syntax in the wiki itself and rules tutorial,
want to trigger an event with
https://www.letscontrolit.com/wiki/inde ... rial_Rules
on <trigger> do
 if <test1>
   event <EventName1>
but later I did see :
Event,StartTimer=1,[INT#11]
I want to use an event with value
is this now correct?
event,eventname=eventvalue?
or
event eventname=evenvalue?
thanks for clarification
T
Re: rule and event within rule syntax
#2 Post by grovkillen » 13 Nov 2019, 18:28
Both comma and space are allowed but preferred is comma.
You can have up to four event values.
Event=1,2,3,4
Use in the block:
%eventvalue1%
%eventvalue4%
But for backwards compatibility you don't need the number if you only have one event value.
Event=1
%eventvalue%
#3 Post by grovkillen » 13 Nov 2019, 18:29
#4 Post by TD-er » 13 Nov 2019, 20:21
Like stated here: https://espeasy.readthedocs.io/en/lates ... mmand.html ("Event Command" section)
Event,SingleValue=123
This is triggering an event called "SingleValue" and it only has one value (123)
So you're acting on the event name like this:
on SingleValue do
  Publish,%sysname%/Info,An event has been sent (%eventvalue%)!
Event,Multi=1,2,3,99
will trigger an event called "Multi" which has 4 values. In the rules block you can access these with %eventvalue1% ... %eventvalue4%
riker1
(solved): rule and event within rule syntax
#5 Post by riker1 » 14 Nov 2019, 07:20
thanks
Users browsing this forum: Semrush [Bot] and 17 guests
