Hi All,
I have just flashed my first espeasy to a ESP8266. I flashes several *.bin files and they are all working.
But on none of them i can find the plugin (_P112_Power.ino Calculate temp. Wh usage.) from ESPEasyPluginPlayground
How can i install this plugin?
thanks
How to install plugins?
Re: How to install plugins?
The code on the playground is highly experimental and some will probably not compile anymore as they may not have been kept in sync with the changes in the core of ESPeasy.
In order to make them work, you have to copy the file into the source code tree of ESPEasy and add the define for it in the define_plugin_sets.h
Then you must compile it yourself.
For some that's close to rocket science or a medical degree, where they mastered neither of the three
Users browsing this forum: Google [Bot] and 55 guests
