Sonoff 2 Gan GPIO,5 at 1 when reboot
fishton
#1 Post by fishton » 10 Dec 2019, 09:34
I have just upgraded my Sonoff 2 gangs used for opening/closing my shuttters to EspEasy mega 20191130 version and I am experiencing an issue I have already seen in the past
Each time the sonoff restarts, GPIO 5 is set to 1 causing my blinds to close.
This was definitely not the case for earlier version I was using (2018-06 as far as I remember)
Do you know how I can prevent that to happen ?
thanks a lot
fishton
Re: Sonoff 2 Gan GPIO,5 at 1 when reboot
#2 Post by grovkillen » 10 Dec 2019, 12:00
Have you tried setting boot state for that pin? It's found under the hardware tab.
fishton
#3 Post by fishton » 10 Dec 2019, 12:29
I tried that in the past and it was not working so I rolled back to previous version but I must confess I didn't this time
I would really like staying with latest version with Wifi stability updates but if the blinds are closing few times a day won't be manageable :)
I will try putting LOW tonight
thanks
Fishton
#4 Post by grovkillen » 10 Dec 2019, 12:59
Yeah try and get back here with info.
fishton
#5 Post by fishton » 11 Dec 2019, 10:22
Hey !
So, I have been able to understand the issue here.
when the Sonoff Touch 2 gang is starting, it looks like Switch 2 (GPIO 9) is set to 1 that was triggering a rule based on that value changing and also changing the relay value
I have added :
on System#Boot do
gpio,12,0
gpio,5,0
inputswithcstate,1,0
inputswithcstate,0,0
in the rules
and also changed both buttons to have "Internal PullUp"
and now I still see the switch 2 light showing up but no more relay activation and the light is switched off afterward
any thoughts ?
thanks
fishton
fishton
#6 Post by fishton » 11 Dec 2019, 10:46
also I tried putting Low on GPIO 9 but it does no have any effect
#7 Post by TD-er » 11 Dec 2019, 11:23
What build did you flash?
It should be ESP8285 and not ESP8266.
GPIO-9 is not available on ESP8266 as it is connected to an external flash chip. On the ESP8285 the flash chip is internal.
fishton
#8 Post by fishton » 11 Dec 2019, 12:32
Hey
I flashed mega 20191208 normal ESP8285 :)
thanks
Domosapiens
#9 Post by Domosapiens » 12 Dec 2019, 00:49
fishton wrote: 11 Dec 2019, 10:22 on System#Boot do
gpio,12,0
gpio,5,0
Typo .. must be inputswitchstate
fishton
#10 Post by fishton » 12 Dec 2019, 13:25
indeed, typo
my rules below
on System#Boot do
event,STOP
on Touch1#Switch1 do
if [Touch1#Switch1]=1 do
gpio,5,0
inputswitchstate 1,0
gpio,12,1
timerSet,1,30 //Set Timer 1 for the next event in 120 seconds
gpio,5,0
gpio,12,0
on Touch2#Switch2 do
if [Touch2#Switch2]=1 do
gpio,12,0
inputswitchstate 0,0
gpio,5,1
timerSet,2,30//Set Timer 1 for the next event in 120 seconds
gpio,12,0
gpio,5,0
On Rules#Timer=1 do
gpio,12,0
On Rules#Timer=2 do //When Timer1 expires, do
gpio,5,0
on UP do
gpio,5,0
gpio,12,1
inputswitchstate 0,1
timerSet,1,30
on DOWN do
gpio,12,0
gpio,5,1
inputswitchstate 1,1
timerSet,2,30
on STOP do
gpio,12,0
gpio,5,0
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 19 guests
