Help needed with Rules (solved)
CPT_MAC
#1 Post by CPT_MAC » 15 Dec 2019, 19:13
please I need some help with rules.
I would like to have the outside light turned on at sunset +15 Minutes and turned off at sunrise -30 Minutes.
So far no problem.
Further I like to get the Garage light turned on, when the Garagedoor are opened and turn off when the door is closed, but only between sunset und sunrise.
The syntax i used just don#t work.
Also in case of a power failure or an reboot the outside light should be on or off depending on night or daytime.
Thx for your help
On Time#initialized do
  if %sunset% > %systime% and %sunrise% < %systime%
    Gpio,13,0
    Gpio,13,1
On Clock#Time=All,%sunset+15m% do  //works
  Gpio,13,0
On Clock#Time=All,%sunrise-30m% do  // works
  Gpio,13,1
On Door_open#Switch=1 do
  if %systime% > %sunset% and %systime% < %sunrise%
    Gpio,4,0
    Gpio,4,1
On Door_open#Switch=0 do   //works
    Gpio,4,1
Re: Help needed with Rules
#2 Post by ThomasB » 16 Dec 2019, 03:55
Maybe your local time is incorrect. To confirm, go to the Main tab and review the reported value. It should match your actual local time. If incorrect, use Tools=>Advanced and update Timezone Offset entry.
CPT_MAC
#3 Post by CPT_MAC » 16 Dec 2019, 10:19
Thanks for your reply Thomas.
But this is not the case. This part works excellent:
Gpio,13,0
Gpio,13,1
I think that I have to use maybe brackets at some points or something else with the syntax I used. Or maybe the format of systime do not match the format of sunset or sunrise.
It does not matter at what time it is, the program always jump to:
Gpio,4,1
and set the gpio 4 to high
wim16
#4 Post by wim16 » 16 Dec 2019, 10:46
Maybe the problem is in your if statement.
When systime > sunset it is often also > sunrise (on the same day) and thus the result will be false.
#5 Post by grovkillen » 16 Dec 2019, 11:55
wim16 wrote:
16 Dec 2019, 10:46
Yep, that's it. Let me think about that one for a while and get back with a suggestion on the rules.
#6 Post by ThomasB » 16 Dec 2019, 19:22
Good catch. For rule simplicity, it would be nice to have a %isDaylight% bool variable. And perhaps a %isTwilight% bool var too. :)
Maybe something like this clumsy workaround would help (example is untested):
  if %systime% < %sunrise% and %systime% < 12:00:00  // Early morning, Is Dark outside.
   let,15,1
   let,15,0
  if %systime% > %sunset% and %systime% > 12:00:00  // Late evening, Is Dark outside.
   let,16,1
   let,16,0
  if %v15%=1 or %v16%=1  // Is Dark outside.
   Gpio,13,0  // Turn On
   Gpio,13,1  // Turn Off
Note: Enter accurate Lat & Long coordinates in Tools=>Advanced (Location Settings section). Confirm the settings are correct by going to Tools=>System Variables and sanity check %sunset% & %sunrise% values.
Hopefully someone posts a better solution. BTW, this rule example would need to be changed to work in geo locations with unusual sunrise/sunset times (Iceland, etc.).
Flying Domotic
#7 Post by Flying Domotic » 17 Dec 2019, 11:47
You may try :
  if %systime% > %sunset% or %systime% < %sunrise%
    Gpio,13,1
    Gpio,13,0
Concerning the door linked light, you could have a small side effect when closing the door during the day: this will turn light off
CPT_MAC
#8 Post by CPT_MAC » 17 Dec 2019, 18:12
Thank you Thomas.
Your workaround works after reboot. This is very good, because ofter reboot the outside Light will be on or off in regards to Daytime or Nighttime.
Further to turn the light on at sunset and off at sunrise with or without offset works.
Perfect so far.
The last thing is to have the Garage light inside on when the Garagentor is open during Nighttime and to keep it off during daytime.
Thank you flying Domotic
Your workaround works too, at least to turn the Garagelight on when the Garagentor at night is open and off when closed. Daytime I will check tomorrow.
    Gpio,4,0
    Gpio,4,1
#9 Post by ThomasB » 17 Dec 2019, 18:34
Thank you Thomas. Your workaround works after reboot. This is very good, because ofter reboot the outside Light will be on or off in regards to Daytime or Nighttime.
Thanks for the feedback. Since Domotic's time compare logic is working you should also use it in the Time#initialized rule instead of my long / clumsy workaround.
