Simple 1-CH relay with ESP8266 bought on Ali + eWelink?
dziekan_tek
#1 Post by dziekan_tek » 17 Dec 2019, 19:07
Hi everyone,
this is my first post and first time of having fun with ESP8266 ;-)
I bought this simple relay with ESP8266 on board on Ali auction:
https://www.aliexpress.com/item/32890526507.html?spm=a2g0s.9042311.0.0.27424c4dhkIahw
The question is if I can configure that module with eWelink? My friend did a flashing for me with ESP Easy but I don't know if it will work with eWelink with that. There are some rules that I can edit but I don't know how to setup. First, I have to know if it will "talk" with eWelink or not :-)
Just one thing I have to add - it has following "devices" in rules page (attached picture).
Thanks in advance for any help and advices!
Best Regards
Dariusz
ESP Easy - type of devices.png (69.62 KiB) Viewed 10444 times
dziekan_tek
Re: Simple 1-CH relay with ESP8266 bought on Ali + eWelink?
#2 Post by dziekan_tek » 17 Dec 2019, 20:09
Or should I change firmware to Tasmota Sonoff? :)
#3 Post by grovkillen » 18 Dec 2019, 03:17
First, welcome to ESP Easy! :D
Second, update the firmware with a newer release.
After that I would simply try GPIO 0,1,2, or 3 and see if any if those trigger the relay. By that being said, you don't need a plug-in to handle a relay, I'd suggest you enable the rules and start playing around there.
PS. no need to pull the Tasmota card out of the sleeve ;)
dziekan_tek
#4 Post by dziekan_tek » 18 Dec 2019, 17:41
I've already checked and GPIO-0 is a LED on ESP board and GPIO-2 is a LED D3 on relay board (it's also the relay, diode just shows the relay state - ON or OFF).
My main purpose is make it working with eWelink because I've already have another 4-CH relay on ESP8285 (PSF-B85) but there case was very easy - I've just pair it with eWelink ;-)
so I wanted to have two relays in one common app on my smartphone :-)
The problem is that this 4-CH has pair button and this ESP-01S board doesn't have - there's only reset button ;-)
#5 Post by grovkillen » 18 Dec 2019, 19:21
Ok, so you want to use eWelink? Then you shouldn't use ESP Easy...
dziekan_tek
#6 Post by dziekan_tek » 18 Dec 2019, 22:56
OK, what other option (apps) do I have, using ESP Easy, to control this relay remotely? And I'm talking about controlling that relay even outside my home network, e.g. via 3G/4G? Is it possible at all?
eWelink uses ITEAD servers, but what could be used with ESP Easy?
#7 Post by grovkillen » 19 Dec 2019, 09:29
There many options, I personally use a MQTT broker and send my data and commands through that one.
dziekan_tek
#8 Post by dziekan_tek » 19 Dec 2019, 18:50
That starting to sound really good... :-)
Do you mean something like that -->
https://www.cloudmqtt.com/plans.html
#9 Post by ThomasB » 19 Dec 2019, 19:53
... what other option (apps) do I have, using ESP Easy, to control this relay remotely? And I'm talking about controlling that relay even outside my home network, e.g. via 3G/4G?
Currently ESPEasy does not offer secure access for controlling outside your local network. So if you're interested in using a cloud service (like eWelink) then ESPEasy isn't the answer.
And regarding security, don't expect any cloud based service to be safe to use. FWIW, eWelink is based in China, a country that hasn't established itself as safe and secure for personal data.
Users browsing this forum: Bing [Bot] and 149 guests
