Using mcp23017 we get 16 GPIOs (A0-A7 / B0-B7).
Under mcpgpio we can trigger pins 1 to 16 as expected.
Monitoring the pins we can get the status of those pins as well.
For some reason I can get the status of "mcpgio,0"
"log": "",
"plugin": 9,
"pin": 0,
"mode": "input",
"state": 0
I assume this is not supposed to exist and I shall ignore it ?
BTW shouldn't syntax of status be "status,mcpgpio,x" to ease the obvious ?
-D
status,mcp,0
status,mcp,0
-D
Re: status,mcp,0
Maybe you can also test the test build of this PR: https://github.com/letscontrolit/ESPEasy/pull/2778
There is some work in progress regarding moving the GPIO handling into single functions, regardless where there are used (still a huge work in progress)
Users browsing this forum: No registered users and 131 guests
