Hi is
is it possible to change the value of Generic - Pulse counter?
I would like to press the GPIO14 button to decrease the value by 1.
Espeasy mega Generic - Pulse counter change value
Re: Espeasy mega Generic - Pulse counter change value
Not directly. But you can create a rule that copies the counter value to a dummy var whenever the counter gets a new count. Then another rule can be used to decrement the dummy var whenever you press the button. You can then publish the dummy var or use it in other rules to control events.
ok thank you
is it possible to update the display value every second?
Fixed, I created a piece counter with forward, back and reset button with proximity sensor to read the pieces.
thank you
thank you
Users browsing this forum: Google [Bot] and 122 guests
