I would like UDP communication for two ESPEASY. On one device I have connected BME280 and on the other OLED SSD 1306. I wanted to send information to the display. Please some rule example. Thank you
UDP communication two espeasy
Re: UDP communication two espeasy
Have a look at following :
https://espeasy.readthedocs.io/en/lates ... #c013-page
Use Dummy Device in the sending unit normally the same dummy device will appears after some time in the receiving unit
you can also use the sendHttp in rules
Syntax Extra information
http://<espeasyip>/control?cmd= <command> Send commands over the HTTP protocol.
Example : http://192.168.1.150/control?cmd=TaskValueSet,1,1,8
or
http://192.168.1.150/control?cmd=TaskValueSet,11,1,[temp#°C]
Patou
or
Patou
Thank you.
Users browsing this forum: No registered users and 54 guests
