Control ESPEasy-thermostat -> Rules problem
hvdwolf
#1 Post by hvdwolf » 05 Feb 2020, 11:25
I control my thermostat via an ESPEasy with a relais. This ESPEasy is controlled from Pimatic (could also be Domotics/OpenHAB/Home Assitant/etc.) with an extensive rule set which works really nice.
However, during my wintersports holiday, the SD-card in my RapberryPi got corrupted -> No more thermostat control. So my house went from the "fixed" temperature of 15 C to 9.5 C.
The ESPEasy itself is of course capable enough to do this all by itself, so I wanted a backup option which I could control directly..
So I wrote an Android app (see attached reduced images) and created a number of dummy devices.
The ESPEasy is connected to my central heating. The livingroom temperature (via event livingroomtemp) is sent by another ESPEasy with a ds18b20. Both are running on the normal 20191208 ESPEasy version.
This can all be controlled from the webGuid, but I also wanted to be able to do it from my phone, hence the Android app (which I can share by the way).
Devices:
And I created a 3 Rules Sets:
Rules Set 1:
On System#Boot do    //When the ESP boots, do
  event InitSettings
  timerSet,1,20      //Set Timer 1 for the next event in 20 seconds
On Rules#Timer=1 do  //When Timer1 expires, do
  if [Thermostat#Enabled]=1 and [Thermostat#Automatic]=0 //active and on manual
      if [Thermostat#Setpoint]>[Thermostat#Temperature]
          TaskValueSet,3,1,1
          TaskValueSet,3,1,0
  if [Thermostat#Enabled]=1 and [Thermostat#Automatic]=1 //active and on auto
      if %sysweekday_s%=Sat or %sysweekday_s%=Sun
          event weekend
          event weekday
  timerSet,1,15      //Set Timer 1 for the next event in 15 seconds
on weekend do
  if %systime% > 07:45:00 and %systime% < 07:45:10
      TaskValueSet,2,3,[InitSetpoints#weday]
  if %systime% > 07:45:10 and %systime% < 22:30:00
      event CheckOnOff
  if %systime% < 07:45:00 or %systime% < 22:30:00
      TaskValueSet,2,3,[InitSetpoints#wenight]
      event CheckOnOff
  //timerSet,1,30      //Set Timer 1 for the next event in 30 seconds
on livingroomtemp do
  TaskValueSet,2,2,%eventvalue%
Rules set 2:
on weekday do
  if %systime% > 06:45:00 and %systime% < 06:45:20
      TaskValueSet 2,3,[InitSetPointsWeekday#wdmorning]
  if %systime% > 06:45:20 and %systime% < 08:00:00
      event CheckOnOff
  if %systime% > 08:00:00 and %systime% < 08:00:20
      TaskValueSet 2,3,[InitSetPointsWeekday#wdday]
  if %systime% > 08:00:20 and %systime% < 16:45:00
      event CheckOnOff
  if %systime% > 16:45:00 and %systime% < 16:45:20
      TaskValueSet 2,3,[InitSetPointsWeekday#wdevening]
  if %systime% > 16:45:20 and %systime% < 22:15:00
      event CheckOnOff
  if %systime% < 06:45:00 or %systime% > 22:15:01
      TaskValueSet 2,3,[InitSetPointsWeekday#wdnight]
      event CheckOnOff
on CheckOnOff
  if Thermostat#Setpoint>Thermostat#Temperature
      //TaskValueSetAndRun,3,1,1
      GPIO,13,1
      //TaskValueSetAndRun,3,1,0
      GPIO,13,0
Rules set 3:
On InitSettings do
  TaskValueSet 2,1,1  //enabled
  //TaskValueSet 2,1,0  //disabled
  TaskValueSet 2,3,18.0 //Setpoint
  TaskValueSet 2,4,1 //Auto=1, manual=0
  Let,1,15  //wdnight
  Let,2,19.5 //wdmorning
  Let,3,18.5 //wdday
  Let,4,20 //wdevening
  TaskValueSet 4,1,[VAR#1]
  TaskValueSet 4,2,[VAR#2]
  TaskValueSet 4,3,[VAR#3]
  TaskValueSet 4,4,[VAR#4]
  // weekend
  Let,5,15.5  //wenight
  Let,6,20 //wemorning
  Let,7,20 //weday
  Let,8,20.5 //weevening
  TaskValueSet 5,1,[VAR#5]
  TaskValueSet 5,2,[VAR#6]
  TaskValueSet 5,3,[VAR#7]
  TaskValueSet 5,4,[VAR#8]
      event initweekend
      event initweekday
on initweekend do
    if %systime% > 07:45:00 and %systime% < 22:30:00
      TaskValueSetAndRun,2,3,[InitSetPointsWeekend#weday]
      TaskValueSetAndRun,2,3,[InitSetPointsWeekend#wenight]
on initweekday do
    if %systime% > 06:45:00 and %systime% < 08:00:00
      TaskValueSetAndRun,2,3,[InitSetPointsWeekday#wdmorning]
    if %systime% > 08:00:00 and %systime% < 16:45:00
      TaskValueSetAndRun,2,3,[InitSetPointsWeekday#wdday]
    if %systime% > 16:45:00 and %systime% < 22:15:00
      TaskValueSetAndRun,2,3,[InitSetPointsWeekday#wdevening]
      TaskValueSetAndRun,2,3,[InitSetPointsWeekday#wdnight]
Everything works fine including my Android app, but for one very essential thing: the heating itself.
on CheckOnOff
      GPIO,13,1
      GPIO,13,0
The GPIO command doesn't switch on the heating (I also tried tthe TaskValueSetAndRun command without success and even the sendTo command as in sendTo,30,13,1 or sendTo,30,13,0 where 30 is my unit number).
What am I doing wrong?
And for those seeing the external address in the Settings: I know it is very dangerous, but I can ssh tunnel via my server with an extra encryption on top of it)
Re: Control ESPEasy-thermostat -> Rules problem
#2 Post by grovkillen » 05 Feb 2020, 11:47
Thanks for posting! Good job.
hvdwolf
#3 Post by hvdwolf » 05 Feb 2020, 12:08
But did you see my question in the last part? ;)
Once that has been fixed I will post it as a project and attach the Android app for those who want to try it themselves.
on CheckOnOff
      GPIO,13,1
      GPIO,13,0
#4 Post by TD-er » 05 Feb 2020, 12:47
Have you added a logitem command in there to see if it does try to set the value?
And if I'm not mistaken, you should also enable gpio monitoring (at boot).
Maybe you can also add a task "switch" which you then run?
hvdwolf
#5 Post by hvdwolf » 05 Feb 2020, 13:39
I added the monitor,13 to the System#boot.
When pimatic controls it, I see it changing. 2 snippets from the log:
211228: Command: gpio
211230: SW   : GPIO 13 Set to 1
211318: SW  : GPIO=13 State=1 Output value=1
211325: EVENT: ThermostatState#HeatingStatus=1.00
228385: Command: gpio
228387: SW   : GPIO 13 Set to 0
228543: SW  : GPIO=13 State=0 Output value=0
228546: EVENT: ThermostatState#HeatingStatus=0.00
When I add the LogEntry to the CheckOnOff
on CheckOnOff
  LogEntry,"In CheckOnOff"
      LogEntry,"Setpoint > Temperature"
      GPIO,13,1
      GPIO,13,0
      LogEntry,"Setpoint <= Temperature"
I see nothing added to the log, for example:
133012: Command: event
133019: EVENT: livingroomtemp=20.0
133046: ACT : TaskValueSet,2,2,20.0
133048: Command: TaskValueSet
135389: EVENT: Rules#Timer=1
135474: ACT : event weekday
135475: Command: event
135476: EVENT: weekday
[b]135569: ACT : event CheckOnOff
135570: Command: event
135571: EVENT: CheckOnOff[/b]
135814: ACT : timerSet,1,15
135815: Command: timerSet
139771: HTTP: status,gpio,13
139773: Command: status
but no gpio changes. What is, or what am I doing wrong?
And the question
is not clear to me. Can you please explain?
Domosapiens
#6 Post by Domosapiens » 05 Feb 2020, 16:55
on CheckOnOff
Must be
on CheckOnOff do
hvdwolf
#7 Post by hvdwolf » 05 Feb 2020, 17:05
Unbelievable that I overlooked that for so long. :shock:
Thanks a lot. That did it.
hvdwolf
#8 Post by hvdwolf » 08 Feb 2020, 12:51
Well, I needed some more changes.
In my first post you can see in Rules Set 1 that I have nested if commands. That is not allowed and therefore doesn't work (and was also overlooked by the gurus on this forum ;)), which I just discovered this weekend as it remained on weekday.
Secondly, which is my stupid fault: On every Timerset1 I check setpoint and switch on/off the relay.
Coincidence or not: my relay was broken this morning. The nodemcu/EspEasy nicely switched on/off but the relay did not activate. I replaced the relay and everything works again.
I will build another if-else: if already on (or off) do not switch again on (or off).
I could not find anything about this, but perhaps a pulse every 15-20 seconds for 6 days (~ 25900 pulses) is too much, also after 3~4 years "normal" use via pimatic. Should these (cheap Chinese) relays be able to cope with that?
#9 Post by TD-er » 08 Feb 2020, 22:21
Please also check to see if you have a diode over the relay to protect the switching electronics.
The coil of the relay may cause a voltage spike when it is deactivated, which may destroy the transistor switching it.
Users browsing this forum: Bing [Bot] and 15 guests
