if-clause not work
Micha_he
if-clause not work
#1 Post by Micha_he » 04 Mar 2020, 22:12
Background: I'll try to execute a rule part, only if the 'absolute' difference between the integer in VAR#1 and the smoothed dummy value (Fuellstand#WertGlatt) is less than 10 or the smoothed value is zero. Here's my if-clause:
if ([INT#1]-[Fuellstand#WertGlatt])^2^.5<10 or [Fuellstand#WertGlatt]=0
I logged the calculation ([INT#1]-[Fuellstand#WertGlatt])^2^.5) and the result is greater then 10, the smoothed value is nearly 90, but the if-tree is executed?! Where is my mistake?
Build is from 10/2019.
Re: if-clause not work
#2 Post by grovkillen » 04 Mar 2020, 22:15
You cannot have the formula like that. You should try using a VAR (using Let command) for that and then do the if on that [VAR#n].
Micha_he
#3 Post by Micha_he » 04 Mar 2020, 22:21
You mean, I've to take this way:
let,2,([INT#1]-[Fuellstand#WertGlatt])^2^.5
if [var#2]<10 or [Fuellstand#WertGlatt]=0
#4 Post by grovkillen » 04 Mar 2020, 22:49
Yes
Micha_he
#5 Post by Micha_he » 04 Mar 2020, 22:53
I'll test it...
Users browsing this forum: dynamicdave and 15 guests
