Arduino UNO --> RS232 --> ESPEasy on ESP12E
Posted: 10 Mar 2020, 12:34
Hello everyone,
My configuration is: Arduino UNO is connected over RX/TX (RS232) to the ESP12E board. Software Version "Release mega-20200305"
In my Arduino UNO is the following code inside:
My problem is that ESPEasy is showing only "TaskValueSet" as recived all the other characters are not displayed, but when I change the code to somthing like that:
Then ESPEasy shows every character in the log, like: "WasSollDerScheissWarum,Geht,Das,Nicht"!
I need the TaskValueSet command to set a Dummy Value like with a temperatur reading from a TSYS01 Sensor.
Does anyone have an idea what the problem is?
Thanks in advance.
regards
Martin
long randNumber;
void setup() {
Serial.begin(115200);
void loop() {
randNumber = random(300);
Serial.println("TaskValueSet,1,1,"+ String(random(100)));
delay(100);
Serial.println("TaskValueSet,1,2,"+ String(randNumber));
delay(100);
Serial.println("TaskValueSet,1,3,0815");
delay(100);
Serial.println("TaskValueSet,1,4,"+ String(analogRead(A0)*(5.0/1023.0)));
delay(100);
Serial.println("WasSollDerScheissWarum,Geht,Das,Nicht);
Thanks in advance.
regards
Martin
