Rule with p2p networking dosn't work
Lansselot
#1 Post by Lansselot » 27 Mar 2020, 12:09
Rule with p2p network dosn’t work
Good day everyone. I’m working on a little quiz button system with 10 buttons and a relay. Wat I want to get at:
- Rest state
- Someone smash a button
- Relay switches for one second to let hear a buzzer
- Light on the button turns on
- No input is possible
- Button 1 resets
- Rest state
This are my devices
See attachment.
The dumy “info#Snellste” while tell the rest witch one shut turn on his light.
I have the following rule working on the relay which acts as a master. This rule checks for button updates, changes the “info#Snellste” number and turns on the relay for one second. Button one brings the “info#Snellste” back to zero.
On quizmister_2_button#State=1 do
 if [info#Snellste]=0
  TaskValueSet 11,1,2
  gpio,0,0
  timerSet,1,1
On quizmister_3_button#State=1 do
  TaskValueSet 11,1,3
  TaskValueSet 11,2,3
  gpio,0,0
  timerSet,1,1
On quizmister_4_button#State=1 do
  TaskValueSet 11,1,4
  gpio,0,0
  timerSet,1,1
On quizmister_5_button#State=1 do
  TaskValueSet 11,1,5
  gpio,0,0
  timerSet,1,1
On quizmister_6_button#State=1 do
  TaskValueSet 11,1,6
  gpio,0,0
  timerSet,1,1
On quizmister_7_button#State=1 do
  TaskValueSet 11,1,7
  gpio,0,0
  timerSet,1,1
On quizmister_8_button#State=1 do
  TaskValueSet 11,1,8
  gpio,0,0
  timerSet,1,1
On quizmister_9_button#State=1 do
  TaskValueSet 11,1,9
  gpio,0,0
  timerSet,1,1
On quizmister_10_button#State=1 do
  TaskValueSet 11,1,10
  gpio,0,0
  timerSet,1,1
On the button site I have almost the same rule bud shorter. This did work, bud not anymore.
 if[info#Snellste]=10
  gpio,0,0
  gpio,0,1
First question: are the variables case sensitive. Does it matter if you type
if [Info#Snellste]=10
or
if [info#snellste]=10
Can someone help me? I try a lot of things bud can’t get it to work.
thank you in advance,
Sander
2020-03-27 11_36_39-Let's Control It - Plaats een nieuw onderwerp.png (62.08 KiB) Viewed 5499 times
Re: Rule with p2p networking dosn't work
#2 Post by grovkillen » 27 Mar 2020, 12:46
What interval do you have for the dummy?
Lansselot
#3 Post by Lansselot » 27 Mar 2020, 15:06
1 second
It looks to me like the if statement is always false while that shouldn't be the case.
#4 Post by ThomasB » 27 Mar 2020, 16:52
  gpio,0,0
  gpio,0,1
The if statement seen above has a typo. There must be a space between if and the [ bracket. Like this:
 if [info#Snellste]=10
Perhaps a space was not required on older firmware (just thinking out loud, I don't know if this is true). But I just tested a similar rule on a recent release; Leaving out this space caused incorrect behavior.
Lansselot
#5 Post by Lansselot » 27 Mar 2020, 18:30
Yes, I also discovered that. Bud this was a typo from me in my post. In the rule on the esp there is a space.
Something else what I tried is trying:
On quizmister_10_button do
 if [quizmister_10_button#State]=1
  gpio,0,0
  gpio,0,1
And this works with no problem. So I would conclude that the problem would be somewhere with reading the "info#Snellste" variable. Whel I see it changing in the devices tap.
#6 Post by ThomasB » 27 Mar 2020, 19:41
My best guess: I suspect that the info#Snellste value changes *after* the quizmister_10_button#State rule is triggered. For the existing logic to work the info#Snellste value would need to be updated before the rule is triggered. This race condition seems to be a "what comes first, chicken or the egg?"
FYI, I noticed that your rule examples are missing the on timer rule that clears the info#Snellste dummy value. If this value is not cleared to zero before each new game then the button event rules will not update it with a new switch value.
BTW, I believe that the rules are executed in a top down fashion, starting on rule page 1. So the winner in a tie condition will be the player with the lowest button number, which is an unfair advantage.
Lansselot
#7 Post by Lansselot » 27 Mar 2020, 21:06
This is true. bud if I press the button again it should still turn on.
I do the reset by pressing button 1 with the following rule.
On quizmister_1_button#State=1 do
 TaskValueSet 11,1,0
And also have the following rule to turn of the relay where the buzzer is connected to.
on Rules#timer=1 do
 gpio,0,1
I think you are right about that. I’m thinking about using MQTT and making a python application and a nice GUI so you get the real quiz fibes. Bud I want to make it stand-alone first.
I just did a little test,
on button 10 I made the following rule:
 gpio,0,0
On quizmister_4_button#State=0 do
 gpio,0,1
This works. so when I press button 4 the light on 10 turns on.
Bud the following should do exact the same thing. Bud doesn’t work.
On quizmister_4_button#State do
if [quizmister_4_button#State]=1
 gpio,0,0
 gpio,0,0
What am I doing wrong?
Now I know that the above named rule works I have a workaround. Bud I’m still confused why the if statement doesn’t work.
One little site note:
  TaskValueSet 11,1,2
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,3
  TaskValueSet 11,2,3
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,4
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,5
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,6
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,7
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,8
  gpio,0,0
  timerSet,1,1
  TaskValueSet 11,1,9
  gpio,0,0
  timerSet,1,1
  gpio,0,0
  timerSet,1,1
This is running build "mega-20190928" and the other buttons are running the newer build "mega-20200310".
Thank you for all you’re time and thinking with me
#8 Post by ThomasB » 27 Mar 2020, 21:54
Maybe the plugin de-bounce setting used in each players' switch is too short and multiple on-off P2P messages are sent on each press. I recommend 100mS and increase if necessary.
Other than that, I don't have any other ideas/suggestions. So if you're not satisfied with your workaround then be patient for more ideas from other users.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 138 guests
