Hello friends,
Sorry I do not find the correct syntax to send a MQTT command from Home assistant to Esp easy
I have tried :
command_topic: 'Esp1/cmd'
payload_on: '=event,ValveOn'
payload_off: '=event,ValveOff'
payload_on: 'event,ValveOn'
payload_off: 'event,ValveOff'
command_topic: 'Esp1/cmd='
Can somebody help me ?
Patou
Syntax for send event via MQTT
Re: Syntax for send event via MQTT
Re: Syntax for send event via MQTT (solved)
Thanks for your answer
Actually I use domoticz and Home assistant
The mqtt controller was set to domoticz.
This is no problem for publishing topics to Home assistant, receiving messages to the generic mqtt helper but do not work with the %sysname%/cmd commands
I set the mqtt controller to home assistant and it works
Patou
Patou
Users browsing this forum: Bing [Bot] and 3 guests
