Rules#Timer and eventvalue
Is it possible to use one 'Rules#Timer' trigger and use the timer# in %eventvalue% ?
I've 6 partially parallel running timer, which mostly execute the same actions.
Re: Rules#Timer and eventvalue
You can create your own events and fire them from rules.
Consider it like calling a function in normal programming languages.
So if you place the 'same actions' in a separate event block and just fire that event, then you may be able to reduce code duplication.
Example (current):
My idea:
With 6 timer I could save some rule-code
On Rules#Timer=1 do
Event,CloseValve=1
LogEntry,ValveClose 1
Let,1,0
EndOn
On Rules#Timer=2 do
Event,CloseValve=2
LogEntry,ValveClose 2
Let,2,0
EndOn
On Rules#Timer=3 do
Event,CloseValve=3
LogEntry,ValveClose 3
Let,3,0
EndOn
On Rules#Timer do
Event,CloseValve=%eventvalue%
LogEntry,ValveClose %eventvalue%
Let,%eventvalue%,0
EndOn
Your wish is a good feature request. I mean why wouldn't the timer event also have an event value that could be used?
I'm a bit surprised this isn't available as %eventvalue%
@TD-er: You think it should work?
Yes it should work that way.
I'll change my rule this evening and report the result here...
I just tested this on current code base and it worked just fine.
On TESTEVENT Do
logentry,%eventvalue%
EndOn
On Rules#Timer DO
Event,TESTEVENT=%eventvalue%
Nice... The feature is added, before I asked for it
I've been using it like that but for custom events, not the timer event. I thought you had tested it and found a bug/missing feature.
You can do it like this too:
So you could send it to different events by name.
On TEST1EVENT Do
logentry,HELLO
EndOn
On Rules#Timer Do
Event,TEST%eventvalue%EVENT
EndOn
Or this one:
Every other run the corresponding variable will be 1 and 0 (alternating).
On TESTEVENT Do
EndOn
On Rules#Timer Do
Let,%eventvalue%,[INT#%eventvalue%#!Z]
Event,TESTEVENT=[INT#%eventvalue%]
EndOn
Works great for me too. ~600byte rule-code saved
That's always nice to see some code duplication was prevented
Users browsing this forum: No registered users and 121 guests
