SlowMotionServo
pic
SlowMotionServo
#1 Post by pic » 16 May 2020, 00:28
Dear all,
I would like to implement the equivalent of this library as a plugin, do you think it's possible for a beginner?
https://github.com/Locoduino/SlowMotionServo
THank you in advance!
Re: SlowMotionServo
#2 Post by ThomasB » 16 May 2020, 02:10
I would like to implement the equivalent of this library as a plugin ...
I didn't see anything obvious in the library that would cause problems for ESPEasy. That is to say, no blocking calls or hard delays.
As far as a beginner writing a ESPEasy plugin, I think success will be up to the "beginner." If you're a ESPEasy newbie but have plenty of C++ coding experience then it should be a pleasant experience. But if this is your first coding rodeo then hang on tight, the ride might get bumpy.
DonnaChapman
Re: SlowMotionServo
#3 Post by DonnaChapman » 16 May 2020, 08:22
Hey. Everything is possible. It only depends on what programming language you use.
pic
Re: SlowMotionServo
#4 Post by pic » 23 May 2020, 22:49
First thank you for your replies!
I spend hours compiling and reading pages like this... but still too time consuming and difficult for me :( I will write directly some lines for what I want, sorry for people who find this post :S
Even ESP"Easy" not so easy behind ! :) beautifull work by the way !
https://diyprojects.io/esp-easy-develop-plugins/#.
