Notify using ssl/tls
Wiki
#1 Post by Wiki » 18 May 2020, 12:31
Is there any plan to use ssl/tls for smtp notifying?
Re: Notify using ssl/tls
#2 Post by TD-er » 18 May 2020, 22:27
For ESP32: Yes
For ESP82xx... Well I have to re-test how many resources (mainly memory) the current encryption layer takes.
We're quite low on free memory and SSL/TLS does take a lot of memory, or at least a little over a year ago it did.
A quick test then showed you needed at least 20k of free memory to use it and that's something we don't have on ESP8266.
Wiki
#3 Post by Wiki » 21 May 2020, 20:31
Ah, OK. Currently no problem for me at all as long as smtp2go still works.
Any roadmap for ESP32 using encryption?
#4 Post by TD-er » 22 May 2020, 12:51
Wiki wrote:
21 May 2020, 20:31
As you may have noticed, the number of ESP32-specific commits and fixes have increased the last few months, so I'm definitely working on getting the ESP32 on par with the ESP8266 regarding support/features/etc.
I can't put a date on it, but given the pull requests made by others for ESP32 also suggest there is an increased demand for ESP32 support.
So I guess the lack of SSL/TLS support on ESP32 will annoy someone else enough to create a PR for it quite soon :)
