MCP23017 plugin using with DHT,DS8b20, Rotary Encoder
Posted: 07 Jun 2020, 11:51
Hi all,
First of all ESPEasy is a great work. Worked on tasmota so far. I chanced to ESPEASY:
Actually i am testing ESPeasy with use of MCP23017 Plugin. I am able to read simple button events and also set leds on and off.
But now i am working on a project for my outdoor sauna.
I am using 2 NODEMCU since i ran out of ports and used udb sendto command.
I want to use only one MCU combined with the port extender MCP23017.
I use following items:
But now is my question. How can i use the py040 or DS8b20 on the IO expander.
best regards Chris
- 3x rotary Encode py040
- 1x DHT, temp and humidity sensor
- 2x simple switch buttons
- 1x relais
best regards Chris
