For days now I've been trying to compile a custom build of Mega in Arduino ide. Actually the only two plugins I would need are P35, the IRTX one and P74 for a TSL2591. That last one is still in test. I'm using Arduino ide 1.8.13 and the latest mega build, Release mega-20200703.
I succeed in compiling whatever custom build I try, accept when I try to add P35 IRTX, which is ruled out by default in define_plugin_sets.h (probably because of the IR library size) I get a compile error:
'st' was not declared in this scope - regarding this line:
st.protocol = strToDecodeType(sprotocol.c_str());
I was able to get rid of that error by adding
stdAc::state_t st, prev;
to that section of the code, but after that it keeps comming up with other 'was not declared in this scope' errors.
Does this make any sense to one of you?
Can't compile Mega with P35 IR plugin
Re: Can't compile Mega with P35 IR plugin
Well the build of the IR plugins is indeed split into a number of options.
For some defines we also created a wrapper.
So it is best for you to define PLUGIN_BUILD_IR
To fix the build issues:
In _P035_IRTX.ino you need to add this define wrapping the handle_AC_IRremote function like this:
I will make a pull request for it.
#ifdef P016_P035_Extended_AC
boolean handle_AC_IRremote(const String &cmd) {
#endif
I noticed a few more build issues when building via Arduino IDE, when I tried to create a custom build via just a few defines in the file ESPEasy.ino.
See pull request: https://github.com/letscontrolit/ESPEasy/pull/3162
Build output in Arduino IDE:
With these 2 defines in ESPEasy.ino:
WARNING: library LiquidCrystal_I2C claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
Executable segment sizes:
IROM : 901796 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 31024 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1764 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 5708 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 35008 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 940292 bytes (90%) of program storage space. Maximum is 1044464 bytes.
Global variables use 42480 bytes (51%) of dynamic memory, leaving 39440 bytes for local variables. Maximum is 81920 bytes.
#define PLUGIN_BUILD_NORMAL_IR
#define USES_P074
Thank you very much! That indeed did the trick!
Users browsing this forum: Google [Bot] and 131 guests
