L.S,
to check if a problem was ESPEasy related i upgraded from an older version (mega-20190404) to the latest version mega-20200703.
(btw, the problem was NOT ESPEasy related.)
i noticed that my %sysname% changed from xxxxx to xxxxx_1.
this seems to be the unit number appended to the unit name.
while i see the need for the HOSTNAME reported to the network to be unique, i fail to see the need for %sysname% to change.
what gives?
%sysname% changed from xxxxx to xxxxx_1 in latest version
Thanks for reading,
regards,
Rob
regards,
Rob
Re: %sysname% changed from xxxxx to xxxxx_1 in latest version
In the "config" tab, there is "Append Unit Number to hostname:"
I tried to make it uniform among all instances where the hostname is generated, but it appeared to be more confusing.
So for now you can uncheck this setting I mentioned.
I will later try to make it more intuitive how the hostname is generated.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
