Send data to Domoticz using HTTP
Wiki
#1 Post by Wiki » 13 Aug 2020, 01:42
The last binaries for 1M devices don't include the Domoticz MQTT controller. So I am trying to submit my data using the http protocol.
Trying to send the data of a bmp280
using
SendToHTTP 192.168.xxx.yyy,8090,'/json.htm?type=command&param=udevice&idx=46&nvalue=0&svalue=[WZTemp#C];[WZTemp#H};[WZTemp#hPa];0'
results in a log entry
610620860: ACT : SendToHTTP 192.168.xxx.yyy,8090,'/json.htm?type=command¶m=udevice&idx=46&nvalue=0&svalue=26.9;;0'
and the data are not recognized by Domoticz.
eehm, did I miss something or is this a bug?
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Wiki
Re: Send data to Domoticz using HTTP
#2 Post by Wiki » 13 Aug 2020, 01:57
Forget it, please, I've foung my typo by myself.
Sending has to be:
SendToHTTP 192.168.xxx.yyy,8090,'/json.htm?type=command&param=udevice&idx=46&nvalue=0&svalue=[WZTemp#C];[WZTemp#H];1;[WZTemp#hPa];0'
But the protocol entry still looks a little bit weired:
611880877: ACT : SendToHTTP 192.168.101.92,8090,'/json.htm?type=command¶m=udevice&idx=46&nvalue=0&svalue=27.0;50;1;1012.54;0'
with the entry between
command
and
udevice=
pi@raspberrypi:~ $
#3 Post by ThomasB » 13 Aug 2020, 03:19
But the protocol entry still looks a little bit weird:
Although not a serious bug, the mangled "param" string could create confusion when someone uses the log to debug http problems. So I would encourage you to report this bug in the Github issue tracker.
#4 Post by TD-er » 13 Aug 2020, 11:02
That's probably caused by &para being replaced by a paragraph symbol in html.
So we should encode the log lines as raw string literals.
Wiki
#5 Post by Wiki » 13 Aug 2020, 12:29
Ah, OK, makes sense.
I'll put it on github.
pi@raspberrypi:~ $
#6 Post by Ath » 13 Aug 2020, 13:16
Well, the bug is probably that "&para" is replaced, instead of the actual html code "¶".
Users browsing this forum: No registered users and 117 guests
