Ghost switch ??
Ghost switch ??
Good morning all,
There you go: I'm trying to do automatic watering with ESPEASY.
The assembly consists of 2 relays mounted so as to reverse the polarity to open or close a solenoid valve.
It works well, except that ... from time to time I have a valve opening without any action. I give you the Rules that I use.
I looked everywhere, using other switches: same. without switch: same. And the whole thing is random. Change the Wemo :same (it's a Wemos D1 mini Pro)
If anyone had a clue, she would be welcome.
Xavier
// Partie automatique
on Clock#Time=All,**:28 do //Mode auto a chaque lever %sunrise% (%sunset% is also available)
if [Etats#Etat_Manuel]=0 and [Bouton#Etat]=1
TaskValueSet 11,2,1
gpio,12,0
gpio,13,1
timerSet,4,1
timerSet,4,0
timerSet,5,0
timerSer,6,0
// Partie Manuelle
on Bouton#Etat=0 do // Mode manuel
if [Bouton#Etat]=0 and [Etats#Etat_Auto]=0
TaskValueSet 11,1,1
gpio,12,0
gpio,13,1
timerSet,1,1
TaskValueSet 11,1,0
//Timers Auto et manuel
on Rules#timer=1 do // Mode manuel Timer1 (ouverture vanne)
gpio,13,0
timerSet,1,0
timerSet,2,5 // Temps arrosage en secondes
on Rules#timer=2 do // Mode manuel Timer2 (arrosage)
gpio,13,0
gpio,12,1
timerSet,2,0
timerSet,3,1
on Rules#timer=3 do // Mode manuel Timer3 (fermeture vanne)
gpio,12,0
TaskValueSet 11,1,0
TaskValueSet 12,1,1
timerSet,3,0
on Rules#timer=4 do // Mode auto Timer4 (ouverture vanne)
gpio,13,0
timerSet,4,0
timerSet,5,5
on Rules#timer=5 do // Mode auto Timer5 (Arrosage)
gpio,13,0
gpio,12,1
timerSet,5,0
timerSet,6,1
on Rules#timer=6 do // Mode auto Timer6 (fermeture vanne)
gpio,12,0
TaskValueSet 11,2,0
timerSet,6,0
Xavier
TaskValueSet 11,2,1
gpio,12,0
gpio,13,1
timerSet,4,1
timerSet,4,0
timerSet,5,0
timerSer,6,0
// Partie Manuelle
TaskValueSet 11,1,1
gpio,12,0
gpio,13,1
timerSet,1,1
TaskValueSet 11,1,0
gpio,13,0
timerSet,1,0
gpio,13,0
gpio,12,1
timerSet,2,0
timerSet,3,1
gpio,12,0
TaskValueSet 11,1,0
TaskValueSet 12,1,1
timerSet,3,0
gpio,13,0
timerSet,4,0
timerSet,5,5
gpio,13,0
gpio,12,1
timerSet,5,0
timerSet,6,1
gpio,12,0
TaskValueSet 11,2,0
timerSet,6,0
- Capture d’écran 2020-08-18 à 10.45.37.png (141.06 KiB) Viewed 8291 times
- Capture d’écran 2020-08-18 à 10.45.11.png (121.75 KiB) Viewed 8291 times
Re: Ghost switch ??
timerSer,6,0
This is a typo?
This is a typo?
Re: Ghost switch ??
Also please check if the ESP may have crashed and rebooted when the valve opens unintended.
If the unit reboots, then some pins may toggle a few times at boot.
See: https://espeasy.readthedocs.io/en/lates ... on-esp8266 and especially the links mentioned there.
Re: Ghost switch ??
And you should really use a pull-up resistor (10k or 4k7 would be fine) on the button input gpio, the internal pull-up of the ESP is too weak to keep it firmly high if the button isn't pressed, so any induction across the wires may fake-push the button.
Re: Ghost switch ??
@ epost : Sorry for the bad typo, bad copy / paste.
@Ath : Good idea for the resistance in external pull-up, I will do that. I thought the internal resistance was enough.
#TD-er : Thanks for the link ( I lost it ) ; I tried with different Wemo D1 mini Pro (V1.0.0), and always had the same result. The weird thing is, nothing happened until I used the "Rules".
Anyway, I'm going to try @Ath's method and put an additional 10K or 4.7K resistor (I have both). I'll let you know.
Thanks a lot. Have a good day.
Xavier
Xavier
Re: Ghost switch ??
Thanks for that hint. I'm also experiencing a "nervous" D1 mini Pro which toggles an input after it's own mind . Have always used internal pull-up, but this time it's with a ~1m cable and a push-button.
Re: Ghost switch ??
Ah, you're experimenting with a very nice antenna mounted as GPIO random generator input
Re: Ghost switch ??
Problem solved: it was a small resistance problem :/
Thank you so much.
The only thing that I changed since yesterday apart from adding a resistor is that I use the D8 (GPIO 15) with a pull-down and adding a resistor of 4K7 (of course ) because I noticed that the TTP223 mounted in pull-up (A closed) does not work permanently (it goes off and you just have to disconnect the ESP for it to restart). I did not find on the internet if it was normal so a little bit of soldering iron and hop in GPIO15.
Have a good day.
Thank you so much.
Have a good day.
Users browsing this forum: No registered users and 113 guests
