currently i'm trying to get esp easy running with my UVR61-3 control unit with the help of P092 but i'm struggeling somehow.
i made a custom build of mega-20201016 to activate the plugin.
i did the HW connection as described in https://espeasy.readthedocs.io/en/lates ... R61-3.html.
the first try did not work at all. i measured the bus signal with an oscilloscope and noticed some distortion of the signal. then i noticed in the code that there is the PULLUP activated, which i think is not necessary here.
P092_ReceivedOK = false;
addLog(LOG_LEVEL_INFO, F("P092_init: Set pin"));
DLbus_Data->ISR_DLB_Pin = CONFIG_PIN1;
pinMode(CONFIG_PIN1, INPUT_PULLUP);
secondly i would ask if there is some documentation about the architecture of an esp easy plugin.
is PLUGIN_WEBFORM_SAVE called every time a click on the webforms "submit" button is done?
i'm trying to debug with log messages and set one message in this state but nothing is displayed in the log when i click the "submit" button.... therefore i was curios about the correct functionality...
thank you for your help!
greets peter
