I use the P1 wifi gateway as a sensor to Domoticz for quite some time. That worked very well up untill i got a new gas meter earlier this week.
The new meter does not show up in Domoticz. All i see is the old meter, which also appears in the smart meter, next to the new gas meter.
One of the Domoticz guys suggested, the new meter is on a differend SBUS channel and so I looked at the raw data.
Now the new gas meter presents its data, starting with 0-2:24.2.1 etc.
Is it possible to forward this to Domoticz too?
New gas meter P1 wifi gateway
Re: New gas meter P1 wifi gateway
ESPEasy P1 gateway doesn't do any filtering on the data, it just 'blindly' forwards the output from the meter to the receiver. Maybe Domoticz supports only 1 gas meter per P1 connection?
Or maybe the utilities guy that installed the new meter should have reset your smart meter, and then reconnect the new gas meter?
Thank you for your answer.
I will ask Domoticz again how to proceed.
The meter guy probably will not return to reset the meter, I think.
Users browsing this forum: Google [Bot] and 148 guests
