Turning an S8 ABC off
JarredAwesome
#1 Post by JarredAwesome » 23 Nov 2020, 17:08
Hey everyone,
I just bought my S8, and am eagerly awaiting it’s arrival.
I have found that there are not a lot of good python Libraries for it.
I want to turn off it’s ABC because it’s going in a very high co2 environment.
I found one library that has a command just called ‘s8_abc’. It doesn’t say if it’s to turn it on, off, set a baseline... anything.
The code it sends to the sensor is: \xfe\x03\x00\x1f\x00\x01\xa1\xc3
Anyone know what this is for?
Re: Turning an S8 ABC off
#2 Post by grovkillen » 23 Nov 2020, 20:13
We're not officially allowing for turning it off. But it's easy to do in the official application from SenseAir. https://senseair.com/media/2001/uip5_0_0_3_40_setup.exe
The reason is that it have done more harm than good when it's too easy to do. But if you know why you're turning it off then the extra step to do it with their UIP5 shouldn't be too much.
JarredAwesome
#3 Post by JarredAwesome » 23 Nov 2020, 20:27
My sensor will be sitting in an environment that is constantly over 5000 ppm. So I feel the abc won’t be a good thing to have on.
I only have a Mac, is there a Linux or max port for that?
JarredAwesome
#4 Post by JarredAwesome » 24 Nov 2020, 16:36
Will powering down the sensor once a day prevent it from auto calibrating?
#5 Post by TD-er » 24 Nov 2020, 16:37
I don't know, but the 1 day interval is not the default interval of the S8.
That's the interval for the MH-Z19 sensors.
JarredAwesome
#6 Post by JarredAwesome » 24 Nov 2020, 17:17
TD-er wrote: 24 Nov 2020, 16:37 I don't know, but the 1 day interval is not the default interval of the S8.
The S8 abc period is 15 days. So I guess my real question is:
If I interrupt the power within the time, will it prevent it from doing abc?
#7 Post by TD-er » 24 Nov 2020, 19:34
I don't know.
JarredAwesome
#8 Post by JarredAwesome » 25 Nov 2020, 16:09
I wrote to Sensair directly.
They sent me this
Page 16 shows how to disable abc
Thanks everyone
Users browsing this forum: No registered users and 25 guests
