Multiple LCD instances
musicpluto
#1 Post by musicpluto » 27 Dec 2020, 09:03
I'm using the software ESP_Easy_mega_20201130_normal_ESP8266_4M1M that allows multiple instances for LCDs. Everything is fine and working. The LCD shows some comming from MQTT. It's a pity, that MQTT is only able to display numbers but no text.
Therefore all the text-information was sent in the past via a http command (http://192.168.2.57/control?cmd=LCD,1,3,Hallo) from NodeRed direkt to the display. Now I have the three instances LCD1, LCD2 and LCD3. The http-command is no longer working. How can I adress these three instances via http? I beleive, that the name or the number of the task has to be a part of these command.
Is there anybody, who knows how to adress these instances? Thank your for your help.
Re: Multiple LCD instances
#2 Post by TD-er » 27 Dec 2020, 10:06
There is a pending PR for it.
https://github.com/letscontrolit/ESPEasy/pull/3198
So it isn't included in the nightly builds right now.
musicpluto
#3 Post by musicpluto » 27 Dec 2020, 11:39
Thank you so much.Then I will wait for the implementation of the PR,
Regards musicpluto
musicpluto
#4 Post by musicpluto » 27 Dec 2020, 11:52
@TD-er: How long, do you think, will it last until these PR will be realized?
#5 Post by TD-er » 27 Dec 2020, 13:40
Not sure, I have been working a lot on other things, working towards a release.
On the other hand the author of the PR (Ton) has made quite a few good quality contributions, so I don't expect a lot of issues regarding compatibility of existing rules.
It also is quite frequently requested as feature.
So I'm still weighing the cons and pros of merging it soon.
musicpluto
#6 Post by musicpluto » 27 Dec 2020, 14:05
Thx!
Musicpluto
#7 Post by Ath » 23 Jan 2021, 14:20
musicpluto wrote: 27 Dec 2020, 11:52 @TD-er: How long, do you think, will it last until these PR will be realized?
@musicpluto:
The PR has been merged and addressing separate tasks with commands using the '[taskname].' prefix syntax is available from release 20210114 (and later).
Taskname can be used with or without square brackets, the period is required (documentation is also updated).
Users browsing this forum: Ahrefs [Bot] and 17 guests
