Hya,
i was using Monitor GPIO and also had this GPIO defined in a virtual button under devices, and while testing, results where weird, and i finally removed the Monitor GPIO and all worked like a charm.
Is there any incompatibility with GPIO monitoring when this GPIO is being used (define) in a device?
Which is the main purpose of Monitor GPIO? verifying the state when this GPIO is not defined under devices?
Thx in advance for any explanation.
Monitor GPIO - question
Re: Monitor GPIO - question
Hmm I may need a bit more info on what's "weird" and how you're using it.
The reason to use the monitor command is to get events when the state of a monitored pin has changed.
Handling events does take quite some resources, so you should not do it on any pin by default.
on the following code i had Monitor GPIO,4
The result was that gpio 04 never had a constat behavior, and with MM on GND and GPIO 4, i never had the voltage.
Please note the GPIO 04 is the VACC device.
When i commented out the Monitor, it worked like a charm. That's why i asked, it monitoring a gpio defined on a device can cause weird behavior.
On System#Boot do
// GPIO,2,0 // status led - inversed - 1 OFF, 0 ON
// Monitor GPIO,4 // D2
timerSet,1,5
gpio,12,0
gpio,13,0
gpio,14,0
let,1,0
let,2,1
on MQTT#Connected do
event,publishstatus
// loop
// events triggered by http
On B58 do // B58 - gpio 14 - D5
pulse,14,1,500
pulse,2,1,500
let,1,1
Publish,%sysname%/B58/status,0
On B24 do // B24 - gpio 12 - D6
pulse,12,1,500
pulse,2,1,500
let,1,1
Publish,%sysname%/B24/status,0
On BOFF do // BOFF - gpio 13 - D7
pulse,13,1,500
pulse,2,1,500
Publish,%sysname%/BOFF/status,0
let,1,2
// events triggered by MQTT
on MQTTIN#BOFF do // cancelled
if %eventvalue%=1
logentry,"mqt boff"
pulse,13,1,500
pulse,2,1,500
let,1,2
on MQTTIN#B58 do // brew 5-8
if %eventvalue%=1
logentry,"mqt b58"
pulse,14,1,500
pulse,2,1,500
let,1,1
on MQTTIN#B24 do // brew 2-4
if %eventvalue%=1
logentry,"mqt b24"
pulse,12,1,500
pulse,2,1,500
let,1,1
on VACC#status do
if %eventvalue%=1 // status = 1
if %v1%=1 // status = 1 var1 = 1
logentry,"Working"
gpio,2,1 // led on
Publish,%sysname%/Notify/status,1 // working
else // status = 0
if %v1%=1 // status = 0 var1 =1
let,1,0
logentry,"Finished"
gpio,2,0 // led off
Publish,%sysname%/Notify/status,0 // finished
if %v1%=2 // status = 0 var1 =2
let,1,0
logentry,"Cancelled"
gpio,2,0 // led off
Publish,%sysname%/Notify/status,2 // cancelled
So you have the switch task + monitoring for GPIO 4?
There is no need for monitoring on that pin if you also have a switch task configured as the switch task will generate events on its own on changes.
I am not sure why it was not working, maybe the extra event handling interfered with the speed needed for the switch task?
seams not being a good idea.. learned the hard way
Users browsing this forum: Bing [Bot] and 143 guests
