publish command with too complex parameters ?
tparvais
#1 Post by tparvais » 11 Jan 2021, 22:10
:idea:
I installed milight bulb on a wemos D1 to play gateway to milight bulb
I succeed to make it run from the web interfaxe or via mqqt command with MQTT Explorer.
I want to use one espeasy to send command in a rule via a publish to mqtt. I tried the same command on espeasy/tools/command working on mqttexplorer:
publish milight/0x8233/rgbw/4,{"state":"ON","brightness":143,"bulb_mode":"color","color":{"r":255,"g":0,"b":0}}
but it does not work : Too many arguments, try using quotes!Command unknown: "publish milight/0x8233/rgbw/4,{"state":"ON","brightness":143,"bulb_mode":"color","color":{"r":255,"g":0,"b":0}}"
I tried to add quote, but no success...
How can I push
to topic milight/0x8233/rgbw/4
Re: publish command with too complex parameters ?
#2 Post by TD-er » 11 Jan 2021, 22:21
See: https://github.com/letscontrolit/ESPEasy/issues/2724
The message you try to send do have normal quotes and commas.
So you must wrap it in commas not used in the parameter, like a single quote.
publish milight/0x8233/rgbw/4,'{"state":"ON","brightness":143,"bulb_mode":"color","color":{"r":255,"g":0,"b":0}}'
tparvais
#3 Post by tparvais » 11 Jan 2021, 22:39
you make my day :) thanks
