skarab
#1
Post
by skarab » 18 Jan 2021, 10:58
Hello everyone.
I'd like to control a Dummy device with a rule on boot and every time a GPIO change of state. So I created two Switch input for my GPI. I'm asking if there a way to combine multiple trigger conditions.
If I've got input switch named GPIO_5 and GPIO_4, I'd like to write something like that :
On System#boot or GPIO_5#state or GPIO_4#state
Obviously I tried and It doesn't work. Is it possible ?
#2
Post
by Ath » 18 Jan 2021, 11:16
No, that's not possible, but
On System#boot do
Event,ProcessState
EndOn
On GPIO_5#state do
Event,ProcessState
EndOn
On GPIO_4#state do
Event,ProcessState
EndOn
On ProcessState do
// Do what you need to do
EndOn
should work as desired.
You can pass on any arguments if needed as well.
skarab
#3
Post
by skarab » 18 Jan 2021, 12:04
Oh great ! You use ProcessState as a function and called it on each trigger!
Thanks for all !
A quick other question :
" Is there a way to duplicate configuration on oher devices"
Because it seem to me that when I use save to upload .dat file, it save the name of the device
#4
Post
by Ath » 18 Jan 2021, 12:20
It does save the unit name, as it is intended to be restored on the same unit. But if your unit-names are exactly the same length you can update (only) that, using a proper binary compatible editor like Notepad++, and restore on the next device.
Be sure to update the unit-number as well after the restore, as those have to be unique as well, but you can't easily edit that in the file.
I haven't found how to export and import this config in JSON format, as that would be much easier to edit.
Post
by TD-er » 18 Jan 2021, 14:13
There isn't (yet) a proper JSON import/export.
We do have a "Settings Archive" (see tools page on "normal" or "custom" builds) which I also used to clone nodes.
When cloning you indeed clone the hostname and unit nr, so after cloning you need to fix that.
When cloning a node, you have to enter the IP of the other node as hostname.
It also supports a set password.
Users browsing this forum: Ahrefs [Bot] and 131 guests
