Notify on temperature lower than 3°C
Beliar_666
#1 Post by Beliar_666 » 22 Jan 2021, 16:40
i have following Problem, i want to use a temperaturesensor and a buzzer to inform me if the temperature goes below 3°C. I tried with following rule:
on Aussen#temperature<3.00 do
 notify 1
Now the Buzzer beeps continuosly if the temperature is below 3°C till temp raises over 3°C. But i just want it to beep once. If i use = instead of < in the rule, it only beeps if temperature is 3°C.
Is there any way to do it like i want?
Re: Notify on temperature lower than 3°C
#2 Post by TD-er » 22 Jan 2021, 16:49
You can do several things here.
The most obvious one is to only set a flag once and inspect it when you receive a temp update event.
But I can imagine it would be useful to set a loop timer (and reset it when the temperature is above some threshold) in which you play a sound or send a notify.
N.B. I suggest to not match the value in the event on...do section, but rather use %eventvalue1% in the handling of the event.
On System#Boot do
  Let,1,0  // Make sure variable 1 is set to 0 at boot
on Aussen#temperature do
  if %eventvalue1% < 3
    if [int#1] = 0
      Let,1,1
      notify 1
    Let,1,0
Not tested, but I guess you get the idea.
Beliar_666
#3 Post by Beliar_666 » 22 Jan 2021, 17:03
Wow. Many thanks, that works.
#4 Post by TD-er » 22 Jan 2021, 17:14
Nice! :)
ciscomike
#5 Post by ciscomike » 17 Mar 2021, 01:31
That was really helpful, thanks a lot.
Users browsing this forum: No registered users and 52 guests
