have tried now several times - it always says " INIT : Cold Boot", it doesnt matter if i reboot it with the button in web interface or I reboot it with the EN button on the device.
here is a hardware button "EN" push log:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0010,len:4
load:0x3fff0014,len:812
load:0x40078000,len:0
load:0x40078000,len:10164
entry 0x400789f8
▒U38 : Info :
INIT : Booting version: (ESP32 SDK v3.2.3-14-gd3e562907)
39 : Info : INIT : Free RAM:290940
39 : Info : INIT : Cold Boot - Restart Reason: CPU0: Vbat power on reset CPU1: for APP CPU, reseted by PRO CPU
40 : Info : FS : Mounting...
82 : Info : CRC : SecuritySettings CRC ...OK
149 : Info : INIT : Free RAM:284920
151 : Info : INIT : SPI not enabled
295 : Info : INFO : Plugins: 47 [Normal] (ESP32 SDK v3.2.3-14-gd3e562907)
297 : Info : EVENT: System#Wake
572 : Info : WIFI : Set WiFi to STA
807 : Info ▒▒▒▒▒▒▒x▒▒ ▒▒х▒сnetwork scan
2316 : Info : WIF▒▒▒▒x▒x▒x▒▒ѥ▒▒▒<blanked> attempt #1
2318 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
2322 : Info : Webserver: start
2323 : Info : WIFI : Starting mDNS...
2324 : Info : WIFI : mDNS started, with name: RolloBackup.local
2329 : Info : OTA : Arduino OTA enabled on port 3232
2342 : Info : EVENT: System#Boot
2434 : Info : ACT : logentry,"Boot#Watcher: 0"
2437 : Info : Boot#Watcher: 0
2445 : Info : ACT : TaskValueSet,1,1,-1
2451 : Info : ACT : TaskValueSet,2,1,-1
2457 : Info : ACT : TaskValueSet,3,1,-1
2463 : Info : ACT : TaskValueSet,4,1,-1
boot with reboot button via GUI: (before I did set boot#watcher to -1, verified in gui before rebooting!
30457 : Info : EVENT: Z1#All=100.00,0.00,0.00,0
30577 : Info : Dummy: value 1: 100.00
30579 : Info : Dummy: value 2: 0.00
30580 : Info : Dummy: value 3: 0.00
30582 : Info : Dummy: value 4: 0
30593 : Info : EVENT: Z2#All=100.00,0.00,0.00,0
30700 : Info : EVENT: Z3#All=100.00,0.00,0.00,0
31680 : Info : Webserver args: 0: 'cmd' length: 6
31681 : Info : : Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400789f8
▒U39 : Info :
40 : Info : INIT : Free RAM:290908
40 : Info : INIT : Cold Boot - Restart Reason: CPU0: Software reset CPU CPU1: Software reset CPU
41 : Info : FS : Mounting...
83 : Info : CRC : SecuritySettings CRC ...OK
150 : Info : INIT : Free RAM:284956
152 : Info : INIT : SPI not enabled
296 : Info : INFO : Plugins: 47 [Normal] (ESP32 SDK v3.2.3-14-gd3e562907)
298 : Info : EVENT: System#Wake
573 : Info : WIFI : Set WiFi to STA
764 : Info : WIFI : Start network scan
2474 : Info : WIFI : Connecting <blanked> attempt #1
2476 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
2479 : Info : Webserver: start
2480 : Info : WIFI : Starting mDNS...
2481 : Info : WIFI : mDNS started, with name: RolloBackup.local
2486 : Info : OTA : Arduino OTA enabled on port 3232
2499 : Info : EVENT: System#Boot
2590 : Info : ACT : logentry,"Boot#Watcher: 0"
2593 : Info : Boot#Watcher: 0
2602 : Info : ACT : TaskValueSet,1,1,-1
2608 : Info : ACT : TaskValueSet,2,1,-1
2613 : Info : ACT : TaskValueSet,3,1,-1
2619 : Info : ACT : TaskValueSet,4,1,-1
2799 : Info : WIFI : Scan finished, found: 4
2847 : Info : Dummy: value 1: -1.00
