Useable on linux hosts, as cronjob on daily basis e.g.
it fetches config and rules*.txt from ESPEasy nodes, compresses the fetched files, checks for duplicates (and only keeps the original one if nothing has changed) and echo's the list of *new* backups.
configure the path and the IPs. the "alswayson" IPs are used to fetch the Inter-ESPEasy Network nodes registered on this ip and added to the backuplist automatically. So if you use the Inter-ESPEasy Network functionality just configure one IP and all your nodes registered at the same port will be backed up. With different Inter-ESPEasy Networks (different ports) just use from each network one Node in the "alwayson" configuration.
If you want some more output uncomment the "echo" in the script. It is so silent because if you have configured your cron daemon to send you emails, you will in the silent configuration only get emails if new backups are made.
feel free to copy, share, modify or whatever you want to do with it.
#!/bin/bash
# configure here your directory for the backups
DIRECTORY="/home/backups/ESPEasy"
DATE=$(date +%Y_%m_%d)
# configure the nodes for Inter-ESPEasy network nodes. They will also be backed up, and all their listed Nodes
declare -a espalwayson=(
"192.168.10.244"
"192.168.10.243"
"192.168.10.233"
# have some nodes which are not part of a Network? Just add them here.
declare -a alwaysbackupespips=(
"192.168.10.234"
"192.168.10.235"
for (( h=1;h<${#espalwayson[@]}+1; h++ )); do
wget http://${espalwayson[$h-1]}/json -q -T 1 -t 1 -O ${DIRECTORY}/json_grepIPs || rm -f ${DIRECTORY}/json_grepIPs
if [ -f ${DIRECTORY}/json_grepIPs ]; then
#echo "Successful fetched json-file from ${espalwayson[$h-1]}"
INTERESPNW=`grep -E '"ip"' ${DIRECTORY}/json_grepIPs | cut -d : -f2 | awk -F\" '{print $2}'`
if [ ! -z "$INTERESPNW" ]; then
INTERESPNWCOUNT=`echo -n "$INTERESPNW" | grep -c '^'`
#echo "Aways-on-Node ${espalwayson[$h-1]} has ${INTERESPNWCOUNT} Inter-ESP Network IPs."
while IFS= read -r line; do
alwaysbackupespips+=("$line")
#echo "Added node ${line} from Aways-on-Node ${espalwayson[$h-1]}"
done <<< "$INTERESPNW"
#else
#echo "Aways-on-Node ${espalwayson[$h-1]} has no Inter-ESP Network Nodes in list."
fi
done
eval espips=($(printf "%q\n" "${alwaysbackupespips[@]}" | sort -u))
declare -a espdownloadfiles=(
"json"
"config.dat"
"rules1.txt"
"rules2.txt"
"rules3.txt"
"rules4.txt"
for (( i=1; i<${#espips[@]}+1; i++ )); do
for (( j=1; j<${#espdownloadfiles[@]}+1; j++ )); do
wget http://${espips[$i-1]}/${espdownloadfiles[$j-1]} -q -T 1 -t 1 -O ${DIRECTORY}/${espdownloadfiles[$j-1]} || rm -f ${DIRECTORY}/${espdownloadfiles[$j-1]}
done
if [ -f ${DIRECTORY}/json ]; then
UNITNAME=`grep -E '"Unit Name"' ${DIRECTORY}/json | cut -d : -f2 | awk -F\" '{print $2}'`
if [ -z ${UNITNAME} ]; then
UNITNAME=`grep -E '"Hostname"' ${DIRECTORY}/json | cut -d : -f2 | awk -F\" '{print $2}'`
fi
(cd ${DIRECTORY}; GZIP=-nq tar --mtime='1970-01-01' -czf ${UNITNAME}_${espips[$i-1]}_${DATE}.tgz config.dat rules*.txt)
#echo "Backup successful for ${UNITNAME}"
#else
#echo "Could not reach ${espips[$i-1]} for backup"
fi
rm -f ${DIRECTORY}/config.dat ${DIRECTORY}/json ${DIRECTORY}/rules*.txt
(cd ${DIRECTORY}; comm -13 <(md5sum * | sort | uniq -w 32 -d) <(md5sum * | sort | uniq -w 32 -D) | cut -f 3- -d" " | xargs -d '\n' rm -f)
done
files=( "${DIRECTORY}"/*${DATE}.tgz )
for file in "${files[@]}"; do
if [ -f ${file} ]; then
echo "${file}"
fi
done
