how to display space before text with siekoo or special characters with dseg7
chromo23
#1 Post by chromo23 » 25 Mar 2021, 14:57
for my multifunctional display project i need help.
i only have colons on my displays so i can only show e.g. the temperature without decimal places. my font for that is dseg7 because it can do space so that the number is in the middle:
[d2].7dtext,.[sensor#Temperature#d2.0]^
i wanted now to display the first decimal place like that:
(as a line under the degree symbol)
[d2].7dtext,.[sensor#Temperature#d2.0]!
therefore i have to use siekoo....
but siekoo doesn´t know spaces so the point (that was displayed as a space in dseg7) will be displayed
What can i do?
and secondly:
how would the code look like to switch between the different signs?
something like that:
if [sensor#Temperature#"use_only_the_first_decimal] <5
Siekoo does know space but not in the beginning of a text
Re: how to display space before text with siekoo or special characters with dseg7
#2 Post by Ath » 25 Mar 2021, 16:27
You can send an unsupported character, like Ä instead of that leading space, or enclose the string in " to prefix with a space
[d2].7dtext," [sensor#Temperature#d2.0]^"
(Couldn't test atm, still at work ;))
chromo23
#3 Post by chromo23 » 25 Mar 2021, 16:42
Ath wrote: 25 Mar 2021, 16:27 You can send an unsupported character, like Ä instead of that leading space, or enclose the string in " to prefix with a space
special characters wont work...they give something... entirely different... :)
but your code works fine! thanks a lot!!!
do you have any suggestions regarding my second problem?
My solution:
Let,6,[sensor#Temperature]*10
Let,7,[sensor#Temperature#D2.0]*10-[int#6]
or not... :)
#4 Post by Ath » 25 Mar 2021, 16:55
Something like this? :
  Let,1,[sensor#Temperature]*10
  Let,2,[sensor#Temperature#F]
  Let,2,[int#2]*10
  Let,3,[int#1]-[int#2]
  if [int#3] < 5
    [d2].7dtext," [sensor#Temperature#d2.0]^" // Degrees only
    [d2].7dtext," [sensor#Temperature#d2.0]!" // Degrees with underline
Edit: Added #F transformation to Let,2,...
chromo23
#5 Post by chromo23 » 25 Mar 2021, 17:15
Problem is, that the integer of the temp value will still be rounded
EDIT:
It works of course:
But if the temp is < .5 its a negative value and else its a positive value because of the rounding
#6 Post by Ath » 25 Mar 2021, 17:20
Then change this line to force a semi-round-down:
(Add the #F 'floor' transformation)
chromo23
#7 Post by chromo23 » 25 Mar 2021, 17:22
Ath wrote: 25 Mar 2021, 17:20 Then change this line to force a semi-round-down:
Or so... both works.. it just depends how you use it in the if statement.
Thanks a lot!
I eventually dit it like this:
Let,7,[int#6]-[sensor#Temperature#F]*10
#8 Post by Ath » 25 Mar 2021, 21:24
chromo23 wrote: 25 Mar 2021, 17:22 I eventually dit it like this:
With rules, the rule 'less is better', should be applied, that's what I eventually also should have ended up with, but I mashed something up quickly ;)
Users browsing this forum: Bing [Bot], Google [Bot] and 143 guests
