flash writes happen to often.....?
chromo23
#1 Post by chromo23 » 13 Apr 2021, 09:29
First of all i am not sure if i understand the flash counter right
Flash Writes:	27 daily / 38 boot
Does that mean i had in 24h 27 flash writes and also 38 reboots?
And will it be reset after 24h or only after a power cycle or flashcounter reset
Why is this happening on a device where it shouldn’t happen at all? (i have a lot espeasy powered devices that don´t do it)
Rules:
on System#Boot do
TaskValueSet 4,1,1
TaskRun,3
On toggle do
  if [Relay#State]=0
    if [dummy#var]=1
      let,2,1
      TaskValueSet 4,1,0
    gpio,12,1
    timerSet,2,14400
    if [var#2]=1
      TaskValueSet 4,1,1
      let,2,0
    gpio,12,0
On Button#State=1 do
event,toggle
On Button#State=11 do
 if [dummy#var]=1
  TaskValueSet 4,1,0
  gpio,12,0
  TaskValueSet 4,1,1
On WiFi#Connected do
  SendToHTTP,api.thingspeak.com,80,/update?api_key=******&field1=[sensor#Temperature]&field2=[sensor#Humidity]
  timerSet,1,59
  Let,1,0
On Rules#Timer=1 do
  Let,1,[VAR#1]+1
 if [var#1]<5
  TaskRun,3
  Let,1,0
 timerSet,1,59
On aan do
       TaskValueSet 4,1,1
On aaus do
       TaskValueSet 4,1,0
On dummy#var=1 do
if [sensor#Humidity]>=75
    gpio,12,1
if [sensor#Humidity]<=71 and [dummy#var2]=1
gpio,12,0
On Rules#Timer=2 do
   event,toggle
On dummy#var do
if [dummy#var]=1
      gpio,13,0
    gpio,13,1
My Devices:
Bildschirmfoto 2021-04-13 um 09.14.57.png (88.05 KiB) Viewed 3819 times
Build: 20110 - Mega (Sonoff s20)
So either the Hardware has an issue or i did something wrong in rules or the rest of the configuration.
Any suggestions?
Re: flash writes happen too often.....?
#2 Post by TD-er » 13 Apr 2021, 15:39
Daily flash write counts is reset after 86400 seconds since last reset of this counter.
The "38" in your example is the number of flash writes since last boot.
chromo23
#3 Post by chromo23 » 13 Apr 2021, 21:36
Thank you...
So if i write once to the flash i should look like this:
1 daily / 1 boot
and after 24h:
0 daily / 1 boot
and the flashwrite since boot will only be reset after i reboot (as well as the daily counter), right?
so it accumulates all the writes...
Re: flash writes happen to often.....?
#4 Post by TD-er » 13 Apr 2021, 23:13
Yep, that's what the code suggests, which I browsed when typing the answer to your question :)
The total writes counter is large enough, that it can hold more writes than the flash can handle (32 bit int)
Users browsing this forum: Bing [Bot] and 38 guests
