Hello, I had to install the minimal + IR version of espeasy (4mb flash), and I noticed that the web log is stripped off the firmware, that's bad because it makes me have to plug the serial to view the IR received commands.
Is it possible to have the minimal version with the web log enabled?
Web Log on IR firmware
Re: Web Log on IR firmware
Hmm not sure why it is disabled on the minimal version.
If you have a syslog service on some computer (e.g. any Linux PC, or Raspberry pi can run it) you can also send your logs to there.
That's probably faster than waiting for a build that has this enabled.
For developing is ok to use the serial.. Should I file a bug report?
Yep, please do open an issue on GitHub for it or else it may be forgotten.
Users browsing this forum: Bing [Bot] and 51 guests
