rule to control relay
I have a wemos d1 mini whit espeasy to which a humidity sensor is attached.
I would like that when I register a certain value, (less than X) an ON command to be sent to the relay with the IP 192.x.x.x (esp01 + tasmota).
somebody can help me pls ?
Re: rule to control relay
Welcome.
First you need to have enabled the Rules feature on the Tools/ Advanced page:
(Tolerant last parameter is optional, both Rules checkboxes should be on)
After that you can enter a new rule in the Rules tab.
I've assumed a BME280 sensor in this example, and the 20 and 30 used are just somewhat randomly selected values.
on BME280#Humidity do
if %eventvalue1% <> %v1%
if %eventvalue% < 20 // A bit dry, turn humidifier on
sendtohttp,192.x.x.x,80,/cm?cmnd=Power%20ON // Turn relay on
if %eventvalue1% > 30 // Humid enough, humidifier off
sendtohttp,192.x.x.x,80,/cm?cmnd=Power%20OFF // Turn relay off
let,1,%eventvalue1% // Save last checked value
humidity information is taken from a soil moisture sensor. I already have the active rule option, because I have another rule. I attach print screen with sensors.
Thanks for the help
Thanks for the help
- sensor.jpg (164.59 KiB) Viewed 6783 times
- rule.jpg (117.07 KiB) Viewed 6783 times
Last edited by florin.ssk@gmail.com on 01 May 2021, 22:02, edited 4 times in total.
Please attach files or screenshots in this forum, not on external, usually unreliable, image storage. After a while they won't be available anymore, so we can't see what was going on.
And rules can be added in a [ code ] [ /code ] tag (without the spaces, I added these so it will show here)
Sending data to Domoticz is (much) easier by using a Controller, preferably the Domoticz MQTT controller, but you will need a MQTT server too (Mosquitto is often used in combination with Domoticz). Domoticz HTTP will do fine too.
I have msqt too .
i have some sensors in the house.
termostat
some shelly 2.5 the control some blinds.
Outside i want to control 1 electrovalve to open/close the water when the soil is to dry. i have the info, but i do not know to make the next step.
i do not know how to configure the rule
i atached the file whit the img.
Thx
termostat
Thx
You can extend the current rule with what I posted before (cleaned it up a bit), that would then be like this:
NB: Each Rules set can contain multiple rules, a new rule starts with 'on <event> do', and ends with 'endon'
on Soil#Analog do // Values are passed via %eventvalue1%..%eventvalue4%, and %eventvalue% is an alias for %eventvalue1%
SendToHTTP,192.168.0.115,8080,/json.htm?param=udevice&type=command&idx=26&nvalue=%eventvalue1%
if %eventvalue% < 1 // A bit dry, turn water pump on
SendToHTTP,192.x.x.x,80,/cm?cmnd=Power%20ON // Turn Tasmota relay on
if %eventvalue1% > 3 // Wet enough, water pump off
SendToHTTP,192.x.x.x,80,/cm?cmnd=Power%20OFF // Turn Tasmota relay off
And....
it's Workig !!
THX !!!
Now, i just find the corect value when the relay must be on/off.
thx again !!!!!
it's Workig !!
THX !!!
thx again !!!!!
Hello again,
the rule made by you works very well. in this way thank you once again.
because the water pressure does not allow I would like to make 2 zones (zone 1 and zone 2) each zone controlled by a 1 relay, but not to run simultaneously. Can you help me change my rule so that
SendToHTTP, 192.x.x.ZZZ, 80, / cm? Cmnd = Power% 20ON // Turn Tasmota relay on
to send the same order to another IP 192.x.x. YYY , but with a delay of 30 minutes?
Thank you,
Thank you,
That should be doable, just to be sure: The seconds relay should be turned on 30 min. after the first is turned on, and also off again 30 minutes after the first is turned off?
Another solution could be to start the second pump after the first one stops, and run it for the same amount of time, if you need that, just ask.
TimerSet,1,1800 // Timer in seconds, 30m * 60 sec.
TimerSet,2,1800 // Timer in seconds, 30m * 60 sec.
on rules#timer=1 do
SendToHTTP,192.x.x.yyy,80,/cm?cmnd=Power%20ON // Turn second Tasmota relay on
on rules#timer=2 do
SendToHTTP,192.x.x.yyy,80,/cm?cmnd=Power%20OFF // Turn second Tasmota relay off
THX!
i gone try like this !
Thank you for your effort. I eventually used variant number 1. in the meantime I discovered that in "domoticz" I can make rules. I used the rule there, which I find easier.
thanks again for your help.
for the delay I used the delay option.
- delay.jpg (38.92 KiB) Viewed 6102 times
- qqqq.jpg (55.9 KiB) Viewed 6102 times
Great, a solution is a solution thanks for reporting back
Users browsing this forum: Google [Bot] and 14 guests
