ESP-Easy_mega_20210503_test_A vs B vs C vs D
Grumpf
#1 Post by Grumpf » 06 May 2021, 13:01
I tried to look in the docs, the readme etc. bit don't seem to understand what is included in each package. Am I missing something ?
Re: ESP-Easy_mega_20210503_test_A vs B vs C vs D
#2 Post by Ath » 06 May 2021, 13:10
It is on this page: https://espeasy.readthedocs.io/en/lates ... lugin.html
Anything that has 'TESTING' assigned is in all test_A/B/C/D set, when 'TESTING A' etc. assigned it is only in that set.
NB: It would be unworkable to provide TESTING sets with any possible combination of plugins, so for the time being, to be able to provide TESTING sets at all, we have this solution. (Previous TESTING set grew too large to hold all plugins with that state).
Grumpf
#3 Post by Grumpf » 06 May 2021, 13:20
Perfect thank you. I think that must be included in the Readme.txt it seems this thing wasn't updated for a while.
Cheers !
#4 Post by Ath » 06 May 2021, 14:12
Ah, yes, that file could use a couple of updates, missed that one when adding these test_A/B/C/D sets. I'll work on that.
Grumpf
#5 Post by Grumpf » 06 May 2021, 14:16
I'm doing an excel sheet that'll list the plugins by release. Maybe it won't be too problematic to have a selection sheet where you select the plugins you want and it tells you what release you can use. If that's useful I can try to help but it'll require a check before each release so that's more work for you. OTOH, if you do one release a month max, I'll probably be able to update it if you warn me of the changes beforehand.
Up to you, thank you for the good work, appreciated !
Grumpf
#6 Post by Grumpf » 06 May 2021, 14:27
Is normal included in all the testings but not necessarily in Display or Energy or is Normal in every version ?
And testing in every Testing A-D ?
#7 Post by Ath » 06 May 2021, 15:40
AFAICS (looking at the build definitions and define_plugin_sets.h), DISPLAY and ENERGY do not have NORMAL set included. And the same goes for most hardware specific sets (hard...) and Custom. Dev build has been removed.
All TESTING builds have the NORMAL and TESTING plugins + the corresponding TESTING A/B/C/D plugins added.
NB: TD-er is working on a website where you can select the plugins you want that builds that .bin for you, but I think it is on the back-burner, that's why I created these (meant as temporary) TESTING build sets A/B/C/D
Grumpf
#8 Post by Grumpf » 06 May 2021, 15:47
Perfect, I'm just looking to quickly modify the readme so it'll be easier for people to figure it out. No need for a complex excel sheet then, just a table will be fine, let me try it.
Cheers!
Users browsing this forum: No registered users and 135 guests
