Disable device for 3 sec from rule
I have have several sensors connected to ESP, including 20x4 LCD, ultrasonic sensor (working as a switch) and ordinary push on button.
Ultrasonic sensor is time consuming device and LCD is slow device so both "disable" processor for a while.
If in the same moment something is loaded to LCD, ultrasonic is working constantly of course and I try to do double click on push-on button, it sometimes does not recognize double click and takes it as a long press.
If ultrasonic disabled manually from menu, everything works correctly.
Is any possibility to disable ultrasonic for 3 sec from rule for proper recognize double click?
Re: Disable device for 3 sec from rule
See: https://espeasy.readthedocs.io/en/lates ... l-commands
TaskEnable / TaskDisable.
So in the rules you can act on some event (e.g. a button press) and disable the task + set a timer for 3 seconds. (command TimerSet)
On the timer event you enable it again.
Hmmm. My FW is probably too old. mega-20191208
Command unknown: "taskenable,5"
Yep, probably.
But I did give you one recently which got really positive reviews
Yep it works !
There is only one problem. You made some tweaks to some software that does not yet have official release.
The compiled FW version you sent me in this post https://www.letscontrolit.com/forum/vi ... 28#p52439 did not have a directive in Custom.h
Would you be so kind and could you compile the same for me but with the above directive?
#define USES_P012_POLISH_CHARS
New build:
https://www.dropbox.com/s/z3blareqkux85 ... M.bin?dl=0
It also has the latest changes from Ton included for P012 with a new "button inversed" option.
So test it first on a 'reachable' node, as I just used the latest source code of today.
Just to be sure, so there will be no new bugs. You know that if you don't test it first on a reachable node, you will introduce new bugs.
Schreudinger, Heisenberg and Murphy will all agree on that, albeit for different reasons
I just downloaded new FW on test device, but Polish letters are not display
LCD config:
Display result:
LCD config:
Display result:
- Letters.jpg (4.8 MiB) Viewed 8732 times
One more problem I noticed with this FW.
If reboot will be done from the "Tools" menu either by command or by clicking menu option, ESP will not connect to the network.
You have to do power cycle.
That must be related to your hardware or network, working here as expected.mackowiakp wrote: ↑16 May 2021, 09:34 One more problem I noticed with this FW.
Do you have any (serial) log available from your NodeMCU during that reboot?
Please try attached (Custom) .bin file, with USES_P012_POLISH_CHARS enabled during compilation.
Reboot command should also work (tested this build on a Wemos D1 mini clone).
- ESP_Easy_mega_20210516_custom_ESP8266_4M1M.zip
- (652.38 KiB) Downloaded 132 times
With this software above, there is no problems with connection to WiFi AP after intended soft reboot.
But still no Polish letters as on photo already posted.
Two test devices was used in this case. Node MCU v2 and v3. Practically no difference between units but from different producer (probably).
To install and test on target device I need additionally "Position - HC-SR04, RCW-0001, etc." named device, that is _P013_HCSR04.
Dont know is it difference (probably no) for tests I use 2x16 LCD but target device has 4x20 LCD.
Hmm what system was Ath's version built on?
I assume it is also built from the same point in the 'mega' branch?
Seeing "WiFi issues" which differ from build to build using the same sources are things I get nightmares from if I think back to those issues in the past.
Yes, current mega state plus some local development stuff, absolutely not related to WiFi (I try to stay away from that as much as possible).
I revert for additional test to FW from this previous link:
What I notice by testing bit longer (using NodeMCU v2 and 3) is WiFi connection problem again. Connection to AP was finally established, but it takes appx. 12-15 min.
Using the last posted FW, such connection take place just in several sec, including reboot procedure.
"Including reboot" as in power cycle?
If not, then it is using the last used connection stored in RTC memory.
I just kept thinking of why the Polish char set is not included in the build.
The only thing I can come up with is that the #ifdef check is done in the .ino file.
So maybe we should move this P012_parseTemplate function to the P012_data_struct file.
That way we can absolutely be sure the defines are properly set when compiling it.
I also plan to do this for the setup() and loop() functions in ESPEasy.ino, as I am really done with the fact (!!!) the build stability is related to the order files are compiled and linked.
Especially with WiFi this flaky behavior is obvious, but now you can also see it in the missing Polish character set decoding.
Can you test this build: https://www.dropbox.com/s/xk04vkay9fu3s ... M.bin?dl=0
The WiFi issues are probably not fixed, but at least the Polish characters should be included. (based on your Custom.h)
Still no Polish letters. Did not notice WiFi issue.
The exact same strings (so exact same settings, without changing) do run on an older version of ESPEasy?
Just to make sure we're not looking at some strange unicode issue here.
I test Your current binary on NodeMCU with 2x16 LCD while target unit (properly displying Polish characters) use 4x20 LCD and mega-20191208 sources.
Also be so kind to include in Custom.h driver _P013_HCSR04 (ultrasonic sensor).
I would like to quote one of my very old posts here with (i think very important notice).
Perhaps depending on the item, the LCD displays differs in the way of programming?
And LCD driver dedicated for mega-20191208 (_P012_LCD.ino) working properly.
And properly working LCD as a photo:The problem is that it is possibility to define only 8 characters while in my language are 18 characters different to ASCII (9 lower and 9 upper case).
At this moment definitions are static. So now I work on possibility to dynamically define such characters. Of course at the one "page" of display there will be always possibility to use only 8 from 18 characters. But it is enough.
During this work, I came across an obstacle that I "fought" for quite a long time.
Well, if we define anything on the address 0x00 CGRAM, then this character is displayed as "null" (not "space") and the character defined on the address 0x01 is distorted.
However, if we define the same character at address 0x00 and at the same time at address 0x08 (which according to docu is not possible), then the character with address 0x00 is still displayed as "null" but the character with address 0x08 is displayed correctly. In addition, the character with address 0x01 is not distorted.
I realize that all what I write here is completely incompatible with the documentation or examples that are available on the Internet. I wonder now. Is it the fault of particular display copies I bought or is it some "undocumented feature" of the LiquidCrystal_I2C.h library. In particular the lcd.createChar command. Or maybe something else?
#ifdef USES_P012
//#################################### Plugin 012: LCD ##################################################
// Sample templates
// Temp: [DHT11#Temperature] Hum:[DHT11#humidity]
// DS Temp:[Dallas1#Temperature#R]
// Lux:[Lux#Lux#R]
// Baro:[Baro#Pressure#R]
// Pump:[Pump#on#O] -> ON/OFF
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C *lcd=NULL;
int Plugin_012_cols = 16;
int Plugin_012_rows = 2;
int Plugin_012_mode = 1;
#define PLUGIN_012
#define PLUGIN_ID_012 12
#define PLUGIN_NAME_012 "Display - LCD2004"
#define PLUGIN_VALUENAME1_012 "LCD"
#define P12_Nlines 4 // The number of different lines which can be displayed
#define P12_Nchars 80
byte LETTER_null[8] = { // spacja
0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000
byte LETTER_a[8] = { // a
0b00000, 0b00000, 0b01110, 0b00001, 0b01111, 0b10001, 0b01111, 0b00010
byte LETTER_c[8] = { // c
0b00010, 0b00100, 0b01110, 0b10000, 0b10000, 0b10001, 0b01110, 0b00000
byte LETTER_e[8] = { // e
0b00000, 0b00000, 0b01110, 0b10001, 0b11111, 0b10000, 0b01110, 0b00010
byte LETTER_l[8] = { // l
0b01100, 0b00100, 0b00101, 0b00110, 0b01100, 0b00100, 0b01110, 0b00000
byte LETTER_n[8] = { // n
0b00010, 0b00100, 0b10110, 0b11001, 0b10001, 0b10001, 0b10001, 0b00000
byte LETTER_o[8] = { // o
0b00010, 0b00100, 0b01110, 0b10001, 0b10001, 0b10001, 0b01110, 0b00000
byte LETTER_s[8] = { // s
0b00010, 0b00100, 0b01110, 0b10000, 0b01110, 0b00001, 0b11110, 0b00000
byte LETTER_z1[8] = { // z z kreska
0b00010, 0b00100, 0b11111, 0b00010, 0b00100, 0b01000, 0b11111, 0b00000
byte LETTER_z2[8] = { // z z kropka
0b00100, 0b00000, 0b11111, 0b00010, 0b00100, 0b01000, 0b11111, 0b00000
byte LETTER_A[8] = { // A duze
0b01110, 0b10001, 0b10001, 0b10001, 0b11111, 0b10001, 0b10001, 0b00010
byte LETTER_C[8] = { // C duze
0b00010, 0b01110, 0b10001, 0b10000, 0b10000, 0b10001, 0b01110, 0b00000
byte LETTER_E[8] = { // E duze
0b11111, 0b10000, 0b10000, 0b11110, 0b10000, 0b10000, 0b11111, 0b00010
byte LETTER_L[8] = { // L duze
0b10000, 0b10000, 0b10010, 0b10100, 0b11000, 0b10000, 0b11111, 0b00000
byte LETTER_N[8] = { // N duze
0b00010, 0b10101, 0b10001, 0b11001, 0b10101, 0b10011, 0b10001, 0b00000
byte LETTER_O[8] = { // O duze
0b00010, 0b01110, 0b10101, 0b10001, 0b10001, 0b10001, 0b01110, 0b00000
byte LETTER_S[8] = { // S duze
0b00010, 0b01111, 0b10100, 0b10000, 0b01110, 0b00001, 0b11110, 0b00000
byte LETTER_Z1[8] = { // Z z kreska
0b00100, 0b11111, 0b01001, 0b00010, 0b00100, 0b01000, 0b11111, 0b00000
byte LETTER_Z2[8] = { // Z z kropka
0b00100, 0b11111, 0b00001, 0b00010, 0b00100, 0b01000, 0b11111, 0b00000
boolean Plugin_012(byte function, struct EventStruct *event, String& string)
boolean success = false;
static byte displayTimer = 0;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_012;
Device[deviceCount].Type = DEVICE_TYPE_I2C;
Device[deviceCount].VType = SENSOR_TYPE_NONE;
Device[deviceCount].ValueCount = 0;
Device[deviceCount].SendDataOption = false;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_012);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_012));
case PLUGIN_WEBFORM_LOAD:
byte choice = PCONFIG(0);
//String options[16];
int optionValues[16];
for (byte x = 0; x < 16; x++)
if (x < 8)
optionValues[x] = 0x20 + x;
optionValues[x] = 0x30 + x;
//options[x] = F("0x");
//options[x] += String(optionValues[x], HEX);
addFormSelectorI2C(F("p012_adr"), 16, optionValues, choice);
byte choice2 = PCONFIG(1);
String options2[2];
options2[0] = F("2 x 16");
options2[1] = F("4 x 20");
int optionValues2[2] = { 1, 2 };
addFormSelector(F("Display Size"), F("p012_size"), 2, options2, optionValues2, choice2);
String strings[P12_Nlines];
LoadCustomTaskSettings(event->TaskIndex, strings, P12_Nlines, P12_Nchars);
for (byte varNr = 0; varNr < P12_Nlines; varNr++)
addFormTextBox(String(F("Line ")) + (varNr + 1), getPluginCustomArgName(varNr), strings[varNr], P12_Nchars);
addRowLabel(F("Display button"));
addPinSelect(false, F("taskdevicepin3"), CONFIG_PIN3);
addFormNumericBox(F("Display Timeout"), F("p012_timer"), PCONFIG(2));
String options3[3];
options3[0] = F("Continue to next line (as in v1.4)");
options3[1] = F("Truncate exceeding message");
options3[2] = F("Clear then truncate exceeding message");
int optionValues3[3] = { 0,1,2 };
addFormSelector(F("LCD command Mode"), F("p012_mode"), 3, options3, optionValues3, PCONFIG(3));
success = true;
case PLUGIN_WEBFORM_SAVE:
PCONFIG(0) = getFormItemInt(F("p012_adr"));
PCONFIG(1) = getFormItemInt(F("p012_size"));
PCONFIG(2) = getFormItemInt(F("p012_timer"));
PCONFIG(3) = getFormItemInt(F("p012_mode"));
char deviceTemplate[P12_Nlines][P12_Nchars];
String error;
if (!safe_strncpy(deviceTemplate[varNr], WebServer.arg(getPluginCustomArgName(varNr)), P12_Nchars)) {
error += getCustomTaskSettingsError(varNr);
if (error.length() > 0) {
addHtmlError(error);
success = true;
case PLUGIN_INIT:
if (PCONFIG(1) == 2) {
Plugin_012_rows = 4;
Plugin_012_cols = 20;
} else if (PCONFIG(1) == 1) {
Plugin_012_mode = PCONFIG(3);
//TODO:LiquidCrystal_I2C class doesn't have destructor. So if LCD type (size) is changed better reboot for changes to take effect.
// workaround is to fix the cols and rows at its maximum (20 and 4)
if (!lcd)
lcd = new LiquidCrystal_I2C(PCONFIG(0), 20, 4); //Plugin_012_cols, Plugin_012_rows);
// Setup LCD display
lcd->init(); // initialize the lcd
lcd->backlight();
lcd->print(F("Czekaj..."));
lcd->createChar(0,LETTER_o); // komorka pamieci uszkodzona zastapiona przez 8
lcd->createChar(1,LETTER_l);
lcd->createChar(2,LETTER_e);
lcd->createChar(3,LETTER_c);
lcd->createChar(4,LETTER_n);
lcd->createChar(5,LETTER_a);
lcd->createChar(6,LETTER_s);
lcd->createChar(7,LETTER_z2);
lcd->createChar(8,LETTER_o);
displayTimer = PCONFIG(2);
if (CONFIG_PIN3 != -1)
pinMode(CONFIG_PIN3, INPUT_PULLUP);
success = true;
case PLUGIN_TEN_PER_SECOND:
if (!digitalRead(CONFIG_PIN3))
if (lcd) {
lcd->backlight();
case PLUGIN_ONCE_A_SECOND:
if ( displayTimer > 0)
displayTimer--;
if (lcd && displayTimer == 0)
lcd->noBacklight();
case PLUGIN_READ:
LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
for (byte x = 0; x < Plugin_012_rows; x++)
String tmpString = deviceTemplate[x];
if (lcd && tmpString.length())
String newString = P012_parseTemplate(tmpString, Plugin_012_cols);
lcd->setCursor(0, x);
lcd->print(newString);
success = false;
case PLUGIN_WRITE:
String tmpString = string;
if (argIndex)
tmpString = tmpString.substring(0, argIndex);
if (lcd && tmpString.equalsIgnoreCase(F("LCDCMD")))
success = true;
argIndex = string.lastIndexOf(',');
tmpString = string.substring(argIndex + 1);
if (tmpString.equalsIgnoreCase(F("Off"))){
lcd->noBacklight();
else if (tmpString.equalsIgnoreCase(F("On"))){
lcd->backlight();
else if (tmpString.equalsIgnoreCase(F("Clear"))){
lcd->clear();
else if (lcd && tmpString.equalsIgnoreCase(F("LCD")))
success = true;
tmpString = P012_parseTemplate(string, Plugin_012_cols);
argIndex = tmpString.lastIndexOf(',');
tmpString = tmpString.substring(argIndex + 1);
int colPos = event->Par2 - 1;
int rowPos = event->Par1 - 1;
//clear line before writing new string
if (Plugin_012_mode == 2){
lcd->setCursor(colPos, rowPos);
for (byte i = colPos; i < Plugin_012_cols; i++) {
lcd->print(" ");
// truncate message exceeding cols
if(Plugin_012_mode == 1 || Plugin_012_mode == 2){
for (byte i = 0; i < Plugin_012_cols - colPos; i++) {
if(tmpString[i]){
lcd->print(tmpString[i]);
// message exceeding cols will continue to next line
else{
// Fix Weird (native) lcd display behaviour that split long string into row 1,3,2,4, instead of 1,2,3,4
boolean stillProcessing = 1;
byte charCount = 1;
while(stillProcessing) {
if (++colPos > Plugin_012_cols) { // have we printed 20 characters yet (+1 for the logic)
rowPos += 1;
lcd->setCursor(0,rowPos); // move cursor down
colPos = 1;
//dont print if "lower" than the lcd
if(rowPos < Plugin_012_rows ){
lcd->print(tmpString[charCount - 1]);
if (!tmpString[charCount]) { // no more chars to process?
stillProcessing = 0;
charCount += 1;
//lcd->print(tmpString.c_str());
// end fix
return success;
// Perform some specific changes for LCD display
// https://www.letscontrolit.com/forum/viewtopic.php?t=2368
String P012_parseTemplate(String &tmpString, byte lineSize) {
String result = parseTemplate(tmpString, lineSize);
const char degree[3] = {0xc2, 0xb0, 0}; // Unicode degree symbol
const char degree_lcd[2] = {0xdf, 0}; // P012_LCD degree symbol
result.replace(degree, degree_lcd);
// See: https://github.com/letscontrolit/ESPEasy/issues/2081
const char znak_a_uni[3] = {0xc4, 0x85, 0}; // Unicode znak a
const char znak_a_lcd[2] = {0x05, 0}; // P012_LCD znak a
result.replace(znak_a_uni, znak_a_lcd);
const char znak_A_uni[3] = {0xc4, 0x84, 0}; // Unicode znak A
result.replace(znak_A_uni, znak_a_lcd);
const char znak_c_uni[3] = {0xc4, 0x87, 0}; // Unicode znak c
const char znak_c_lcd[2] = {0x03, 0}; // P012_LCD znak c
result.replace(znak_c_uni, znak_c_lcd);
const char znak_C_uni[3] = {0xc4, 0x86, 0}; // Unicode znak C
result.replace(znak_C_uni, znak_c_lcd);
const char znak_e_uni[3] = {0xc4, 0x99, 0}; // Unicode znak e
const char znak_e_lcd[2] = {0x02, 0}; // P012_LCD znak e
result.replace(znak_e_uni, znak_e_lcd);
const char znak_E_uni[3] = {0xc4, 0x98, 0}; // Unicode znak E
result.replace(znak_E_uni, znak_e_lcd);
const char znak_l_uni[3] = {0xc5, 0x82, 0}; // Unicode znak l
const char znak_l_lcd[2] = {0x01, 0}; // P012_LCD znak l
result.replace(znak_l_uni, znak_l_lcd);
const char znak_L_uni[3] = {0xc5, 0x81, 0}; // Unicode znak L
result.replace(znak_L_uni, znak_l_lcd);
const char znak_n_uni[3] = {0xc5, 0x84, 0}; // Unicode znak n
const char znak_n_lcd[2] = {0x04, 0}; // P012_LCD znak n
result.replace(znak_n_uni, znak_n_lcd);
const char znak_N_uni[3] = {0xc5, 0x83, 0}; // Unicode znak N
result.replace(znak_N_uni, znak_n_lcd);
const char znak_o_uni[3] = {0xc3, 0xB3, 0}; // Unicode znak o
const char znak_o_lcd[2] = {0x08, 0}; // P012_LCD znak o
result.replace(znak_o_uni, znak_o_lcd);
const char znak_O_uni[3] = {0xc3, 0x93, 0}; // Unicode znak O
result.replace(znak_O_uni, znak_o_lcd);
const char znak_s_uni[3] = {0xc5, 0x9b, 0}; // Unicode znak s
const char znak_s_lcd[2] = {0x06, 0}; // P012_LCD znak s
result.replace(znak_s_uni, znak_s_lcd);
const char znak_S_uni[3] = {0xc5, 0x9a, 0}; // Unicode znak S
result.replace(znak_S_uni, znak_s_lcd);
const char znak_z1_uni[3] = {0xc5, 0xba, 0}; // Unicode znak z z kreska
const char znak_z1_lcd[2] = {0x07, 0}; // P012_LCD znak z z kropka
result.replace(znak_z1_uni, znak_z1_lcd);
const char znak_Z1_uni[3] = {0xc5, 0xb9, 0}; // Unicode znak Z z kreska
result.replace(znak_Z1_uni, znak_z1_lcd);
const char znak_z2_uni[3] = {0xc5, 0xbc, 0}; // Unicode znak z z kropka
const char znak_z2_lcd[2] = {0x07, 0}; // P012_LCD znak z z kropka
result.replace(znak_z2_uni, znak_z2_lcd);
const char znak_Z2_uni[3] = {0xc5, 0xbb, 0}; // Unicode znak Z z kropka
result.replace(znak_Z2_uni, znak_z2_lcd);
char unicodePrefix = 0xc3;
if (result.indexOf(unicodePrefix) != -1) {
const char umlautAE_uni[3] = {0xc3, 0x84, 0}; // Unicode Umlaute AE
const char umlautAE_lcd[2] = {0xe1, 0}; // P012_LCD Umlaute
result.replace(umlautAE_uni, umlautAE_lcd);
const char umlaut_ae_uni[3] = {0xc3, 0xa4, 0}; // Unicode Umlaute ae
result.replace(umlaut_ae_uni, umlautAE_lcd);
const char umlautOE_uni[3] = {0xc3, 0x96, 0}; // Unicode Umlaute OE
const char umlautOE_lcd[2] = {0xef, 0}; // P012_LCD Umlaute
result.replace(umlautOE_uni, umlautOE_lcd);
const char umlaut_oe_uni[3] = {0xc3, 0xb6, 0}; // Unicode Umlaute oe
result.replace(umlaut_oe_uni, umlautOE_lcd);
const char umlautUE_uni[3] = {0xc3, 0x9c, 0}; // Unicode Umlaute UE
const char umlautUE_lcd[2] = {0xf5, 0}; // P012_LCD Umlaute
result.replace(umlautUE_uni, umlautUE_lcd);
const char umlaut_ue_uni[3] = {0xc3, 0xbc, 0}; // Unicode Umlaute ue
result.replace(umlaut_ue_uni, umlautUE_lcd);
const char umlaut_sz_uni[3] = {0xc3, 0x9f, 0}; // Unicode Umlaute sz
const char umlaut_sz_lcd[2] = {0xe2, 0}; // P012_LCD Umlaute
result.replace(umlaut_sz_uni, umlaut_sz_lcd);
return result;
#endif // USES_P012
That part of the code:
and accompanying stuff isn't present in the latest P012 release, so I think that should be added to the update TD-er already PR'ed today, as it sets up some extra characters. Haven't yet been able to track when that part of code was removed.
Added it to the PR: https://github.com/letscontrolit/ESPEas ... b8225c188b
Taken the custom char definition from https://github.com/letscontrolit/ESPEasy/issues/2669
Yep. WORKS on test device !
No WiFi issue too (so far).
One small remark. I place in my code string "Czekaj..." ("Wait" in my language) in place "ESP Easy".
So current binary during initialization LCD display "ESP EasyCzekaj..". Be kind to remove one of them, probably my one.
Will try on target device later
I removed the Polish Wait...
I will merge it, but be aware the WiFi issues have not yet been fixed.
Last night I had one of my own units (connected to serial log) showing the issue of not reconnecting.
So I could see what was wrong then. It appeared the WiFi events were not considered to timeout, so if not all events were processed (e.g. more likely to happen on static IP) it would wait forever (until it crashed....)
So I do have to take a closer look at it, as it is possible to get in the situation where a new connection cannot be started as there are unprocessed wifi events and those events cannot be processed as they are waiting for another event to happen first.
OK. Work in progress !
When the new, official release of the sources will be available, and I get from China the LCD version with a character generator containing Cyrillic characters in the second half of CharROM (such version is available on Ali), I will add mapping of Cyrillic codes to CharROM addresses.
This is important in my country because we have over 1.8 million immigrants from Ukraine, Belarus and Russia.
And they all plan on using ESPEasy?mackowiakp wrote: ↑18 May 2021, 12:26 [...]
Probably not all of them .
But for example most ticket vending machines, ATM machines, information lines in banks, information boards in state offices, shops etc. have the option of Ukrainian and/or Russian language.
So for future projects.
And these are beavers 150 meters from my house. Pests ...
https://www.dropbox.com/s/g8opspy49yi0jxg/Bobr.mp4?dl=0
Users browsing this forum: Bing [Bot], Google [Bot] and 150 guests
