Time & Timer Control
Lonzo
#1 Post by Lonzo » 01 Jun 2021, 13:48
Hi, I tried so much, but no good results. What I want is this (in rules):
GPIO x has to switch ON every 20 Minutes for 2 Minutes if systime >10.00 and <22:00
GPIO x has to switch ON every 1 hour for 2 Minutes if systime >22:00 and <10:00
Is anyone able to give me some hints?
Thank you
Lonzo
Re: Time & Timer Control
#2 Post by TD-er » 01 Jun 2021, 14:39
See here for a list of events:
https://espeasy.readthedocs.io/en/lates ... tem-events
You want probably act on Time#Initialized
In this example I set 2 timers:
timer 1: turn off and schedule timer 2 based on the system time
timer 2: turn on and schedule timer 1 to turn it off.
on Time#Initialized do
  timerset,1,120 // Set off timer to 2 minutes
  gpio,2,1  // Turn on GPIO2
on Rules#Timer=1 do
  // Timer to turn off the GPIO
  gpio,2,0 // Turn off GPIO 2
  let,1,1080 // Set variable 1 to (20 - 2) minutes in seconds
  If %systime% > 10:00:00
    let,1,3480 // Set variable 1 to (60 - 2) minutes in seconds
  If %systime% > 22:00:00
  timerset,2,[int#1] // Set timer 2
on Rules#Timer=2 do
Lonzo
#3 Post by Lonzo » 01 Jun 2021, 15:28
Thank you. I will study and try it.
Lonzo
Lonzo
#4 Post by Lonzo » 13 Jun 2021, 17:14
@TD-er: Thank you very much! It works. I had to adjust some parameters and I am happy.
Lonzo
#5 Post by TD-er » 13 Jun 2021, 19:26
Great :)
Users browsing this forum: No registered users and 50 guests
