Reboot tracking
marstu
Reboot tracking
#1 Post by marstu » 13 Jun 2021, 20:28
Hi all,
I have a new idea, and would like to track the reboots of my ESPs on a daily basis (clear variable right before midnight) in a dummy device due to this rule, which is working very well:
on System#Boot do
  timerSet,1,60  // Set timer 1
on WiFi#Disconnected do
on WiFi#Connected do
  timerSet,1,0  // Clear timer 1
On Rules#Timer=1 do
  Reboot
endOn
My idea was the following:
on Clock#Time=All,23:59 do //will run once a day at noon
 Let,16,0
On System#Boot do
  TaskValueSet 6,1,[var#16]+1 //will this survive a reboot?
I guess there is a slight mistake and this
On System#Boot do
should ready as
On System#Reboot do
Please correct me if I am wrong?
Merci already and kind regards
marstu
ESP8266, ESPEasy (always latest mega release in use :D ), and Domoticz (only beta versions :) )
Re: Reboot tracking
#2 Post by TD-er » 13 Jun 2021, 20:38
Variables do not survive a reboot, but task variables do.
So you could store something in a dummy task and try to read it at boot.
N.B. This is somewhat unreliable on ESP32, but on ESP8266 it does work, as long as you don't power cycle the node.
marstu
Re: Reboot tracking
#3 Post by marstu » 13 Jun 2021, 20:58
TD-er wrote: 13 Jun 2021, 20:38 Variables do not survive a reboot, but task variables do.
Ok, again not thought out correctly. Next try is something like that:
 TaskValueSet 6,1,0
On System#Boot do
  TaskValueSet 6,1,[Reb_Count#Reboots]+1 //will this survive a reboot?
But how can I increase this task variable after each reboot? I guess I need something different to [var#16]+1, but what is exactly required? [Reb_Count#Reboots]+1 might this be an idea?
TD-er wrote: 13 Jun 2021, 20:38 N.B. This is somewhat unreliable on ESP32, but on ESP8266 it does work, as long as you don't power cycle the node.
It is a ESP8266, I am not yet into ESP32s.
marstu
Re: Reboot tracking
#4 Post by marstu » 13 Jun 2021, 21:05
marstu wrote: 13 Jun 2021, 20:58
 TaskValueSet 6,1,0
On System#Boot do
Tested and it is working as expected, thanks for the helpful hint.
Users browsing this forum: Bing [Bot] and 129 guests
