Display Off via rule
marstu
#1 Post by marstu » 19 Jun 2021, 22:07
Hi all,
It's again me, with a new question. I try to switch my small OLED display via the following rule:
on %sysweekday%>0 and %sysweekday%<6 do
 If %systm_hm% < 19:00 and %systm_hm% > 08:00
  OledFramedCmd,display,on
  OledFramedCmd,display,off
But obviously it is not working. Display should be off during 19:00 and 8:00 from Monday to Friday, and completely in the weekend. Where is the mistake? Do I need another trigger?
Thanks already and kind regards
marstu
ESP8266, ESPEasy (always latest mega release in use :D ), and Domoticz (only beta versions :) )
Re: Display Off via rule
#2 Post by ThomasB » 20 Jun 2021, 04:29
I'm a bit unsure what you want (OLED off during daytime or off during night time). From your code I think you want the display only on during the daytime and always off on the weekend. So that's what I coded. You can change it if that's not what you need.
on Clock#Time=All,**:** do
 LogEntry,"Processing One-Minute Clock Event: Time is %systm_hm%, Day=%sysweekday%"
  if %sysweekday%>1 and %sysweekday%<7  // Allowed Date Range, Mon=2, Fri=6
   LogEntry,"Mon(2)-Fri(6) Detected, (Day=%sysweekday%)"
   if %systm_hm% > 08:00 and %systm_hm% < 19:00 // 8AM - 7:00PM Time Range
     LogEntry,"Oled Display Turn On Time"
     LogEntry,"Oled Display Turn Off Time"
     LogEntry,"Weekend:Turn Off Oled Display"
The Clock#Time event will be triggered once per minute. This is what runs the rule.
I can't verify the rule since I don't use an OLED. If doesn't work then use serial log to assist with the debugging.
marstu
#3 Post by marstu » 20 Jun 2021, 13:02
ThomasB wrote: 20 Jun 2021, 04:29
Wow, thanks it is working, well done.
marstu
Users browsing this forum: No registered users and 100 guests
