I need help with my dashboard
chromo23
#1 Post by chromo23 » 12 Oct 2021, 16:23
I made me a new dashboard since i needed modern functions like async and sending requests in background rather then loading the hole page.
My old dashboard.esp:
Bildschirmfoto 2021-10-12 um 15.46.39.png (43.79 KiB) Viewed 6304 times
My new "dashboard".html:
Bildschirmfoto 2021-10-12 um 15.49.08.png (31.28 KiB) Viewed 6304 times
As you can see, the svg image is missing in the new version because i don't know how to load an image depending on the status of a value.
With the old code it was easy: (the value is either 0 or 1 so i named the images Lamp0.svg and Lamp1.svg)
<center>
<table>
<tr><img src="Lamp[dummy#boost].svg" width="70" height="70" alt>
<br><br>
<td><a class='button' href="dashboard.esp?cmd=event,boost">Boost</a>
</table>
</center>
But how do i implement this in my new version.
I am a real beginner with this and before i spend more hours than i already have i thought i could ask for help....
Here the code of the new dashboard:
<!DOCTYPE html>
<html>
<link rel="stylesheet" href="esp.css">
<meta name="viewport" content="width=width=device-width, initial-scale=1">
<STYLE>
        font-family: sans-serif;
        font-size: 14pt;
        background-color: #2b2a2a;
        color: #fff;
    .button {
        margin: 4px;
        padding: 14px 60px;
        color: #FFF;
        text-decoration: none;
        border-radius: 14px
</STYLE>
<head>
    <script onload="setInterval()">
        setInterval(async function () {
            response = await fetch("json?view=sensorupdate");
            myJson = await response.json();
            tempSoll = myJson.Sensors[5].TaskValues[0].Value;
            document.getElementById("tempSollId").innerHTML = tempSoll;
            tempVar = myJson.Sensors[7].TaskValues[0].Value;
            document.getElementById("tempVarId").innerHTML = tempVar;
            humVar = myJson.Sensors[7].TaskValues[1].Value;
            document.getElementById("humVarId").innerHTML = humVar;
        }, 1000);
    </script>
</head>
<body>
    <div style="overflow-x:auto;">
        <br><br>
        <br><br>
        <center>
            <table>
                <tr>
                    <td style=font-size:30px;"> Soll:</td>
                    <td style=font-size:30px;" id="tempSollId">Tsoll</td>
                    <td style=font-size:30px;">&#8451;</td>
                </tr>
            </table>
        </center>
        <center>
            <table>
                <tr>
                    <td style="text-align:right;"><a class='button' onclick="submitdown()">-</a>
                    <td style="text-align:left;"><a class='button' onclick="submitup()">+</a>
                </tr>
                <br><br>
            </table>
        </center>
        <br><br>
        <center>
            <table>
                <tr style="text-align:center;">Aktuell:</tr>
                <tr>
                    <td>Temperature:</td>
                    <td id="tempVarId">Temp</td>
                    <td>&#8451;</td>
                </tr>
                <tr>
                    <td style="text-align:right;">Humidity:</td>
                    <td id="humVarId">Hum<td style="text-align:left;" >%</td> </td>
                </tr>
            </table>
        </center>
        <br><br>
        <center>
            <table>
                <tr>
                    <br><br>
                    <br><br>
                    <td><a class='button' onclick="submitboost()">Boost</a>
                </tr>
            </table>
        </center>
        <br><br>
        <script type="text/javascript">
            function submitdown() {
                var xhr = new XMLHttpRequest();
                xhr.onreadystatechange = function () {
                    if (xhr.readyState === 4) {
                xhr.open('get', 'control?cmd=event,down', true);
                xhr.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
                xhr.send();
        </script>
            function submitup() {
                xhr.open('get', 'control?cmd=event,up', true);
                xhr.send();
        </script>
            function submitboost() {
                xhr.open('get', 'control?cmd=event,boost', true);
                xhr.send();
</script>
    </div >
chromo23
Problem solved: dynamic dashboard
#2 Post by chromo23 » 15 Oct 2021, 10:23
Problem solved:
Dynamic image loading for the indicator lamp now works and switching between light and dark mode too...
i got the info from another forum and i was also told, that the html is not quite up to date so i changed it. :)
<!DOCTYPE html>
<html>
<link rel="stylesheet" href="/esp.css">
<meta name="viewport" content="width=device-width, initial-scale=1">
<STYLE>
    body {
        margin: 0;
    #container {
        height: 70vh;
        display: flex;
        justify-content: space-around;
        flex-direction: column;
        align-items: center;
        padding-top: 20%
    #plusminus {
        display: flex
    .boost {
        padding-top: 10%
    .aktuell {
        padding-top: 5%
    a {
        display: inline-block;
    div {
        text-align: center;
    .temp.soll span {
        /*font-size: 30px;*/
    .button {
        margin: 4px;
        padding: 14px 60px;
        border-radius: 14px;
        display: block
    .button:hover {
        background-color: #07D;
        display: block;
    .button:active {
        background-color: #44607a;
        display: block;
        transform: scale(1.1);
        -webkit-transform: scale(1.1);
        transition: 0.1s
    @media (prefers-color-scheme: dark) {
            background-color: #222
        .button:hover {
</STYLE>
        boostVar = myJson.Sensors[6].TaskValues[0].Value;
        document.getElementById('lamp').src = 'Lamp' + boostVar + '.svg';
    }, 1000);
</script>
        xhr.send();
</script>
        xhr.send();
</script>
        xhr.send();
</script>
<div id="container">
    <div class="temp soll">
        <a> Soll:</a>
        <br>
        <span style="font-size:60px" id="tempSollId">0</span>
        <span>&#8451;</span>
    </div>
    <div id="plusminus">
        <a class="button" onclick="submitdown()">-</a>
        <a class="button" onclick="submitup()">+</a>
    </div>
    <div class="aktuell">
        Aktuell:
        <div>
            <span>Temperature:</span>
            <span id="tempVarId">0</span>
        </div>
        <div class="hum">
            <span>Humidity:</span>
            <span id="humVarId">0</span>
        </div>
    </div>
    <div class="boost">
    <img id="lamp" src="Lamp0.svg" width="80" height="80" alt>
    <a class="button" onclick="submitboost()">Boost</a>
</div>
</div>
Re: I need help with my dashboard
#3 Post by TD-er » 15 Oct 2021, 12:50
That's looking good.
Can I use your code to add it to the ReadTheDocs documentation as an example for the dashboard feature?
chromo23
#4 Post by chromo23 » 15 Oct 2021, 12:51
TD-er wrote: 15 Oct 2021, 12:50 That's looking good.
You are very welcome to do so!
chromo23
#5 Post by chromo23 » 15 Oct 2021, 14:28
Next step could be this:
chromo23
#6 Post by chromo23 » 15 Oct 2021, 15:10
@TD-er
this is used to fetch the units right?
<script><
            function dept_onchange(frmselect) { frmselect.submit(); }
            </script>
Can you show me how to implement this that it displays the units like this:
<div id="mySidenav" class="sidenav">
    <a href="javascript:void(0)" class="closebtn" onclick="closeNav()">&times;</a>
    <a href="#">node1</a>
    <a href="#">node2</a>
    <a href="#">node3</a>
    <a href="#">node4</a>
  </div>
#7 Post by TD-er » 15 Oct 2021, 15:33
Actually, I have no idea as I have not yet done a lot with this dashboard functionality.
Also I don't speak JavaScript very well. As soon as Stackoverflow is down, I completely loose my ability to do anything JavaScript related.
I have programmed in a lot of computer languages, but somehow I never got the hang of JavaScript. It's a real shame.
But this is really something which is way too much underappreciated as the dashboard functionality is really quite powerful.
So if you can dive into this and help get it clear (read: document it :) ) I would really appreciate it.
chromo23
#8 Post by chromo23 » 15 Oct 2021, 16:57
TD-er wrote: 15 Oct 2021, 15:33 Actually, I have no idea as I have not yet done a lot with this dashboard functionality.
At least you are the one-eyed among the blind in this thread.... ;)
I try to dive into it but i am beginning from zero so it probably takes some time or maybe someone is coming for the rescue...
chromo23
#9 Post by chromo23 » 15 Oct 2021, 21:18
I added a sidebar for easy node access and a "homebutton"....
#10 Post by TD-er » 16 Oct 2021, 01:01
Cool :)
chromo23
#11 Post by chromo23 » 16 Oct 2021, 14:16
That's it .. I´ll do now a little bit of weekend.
I can´t really get my head wrapped around these syntaxes... :?
I´t works so have Fun with testing if you like.
It´s missing a node highlight in the menu as an indicator where you at right now and the json requests need to be optimized.
<!DOCTYPE html>
<html lang='en'>
<STYLE>
    body {
        margin: 0;
    #container {
        height: 100vh;
        display: flex;
        min-height: 500px;
        margin: auto;
        padding: 20%
    #plusminus {
        display: flex
    .boost {
        padding-top: 10%
    .aktuell {
        padding-top: 5%
    a {
    div {
        text-align: center
    .temp.soll span {
    .button {
        margin: 4px;
        padding: 14px 60px;
        display: block
    .button:hover {
        display: block
    .button:active {
        display: block;
        transition: 0.1s
    #opener {
        padding: 20px;
        min-width: 150px;
        display: flex;
        flex-direction: row;
        flex-wrap: nowrap;
        justify-content: space-between;
        align-items: center
    .sidenav {
        height: 100%;
        width: 0;
        position: fixed;
        z-index: 1;
        top: 0;
        left: 0;
        background-color: #111111d9;
        overflow-x: hidden;
        transition: 0.5s;
        display: flex;
        flex-wrap: nowrap;
        justify-content: center;
    .sidenav a {
        padding: 8px 8px 8px 8px;
        font-size: 25px;
        display: block;
        transition: 0.3s;
        background: transparent
    .sidenav a:hover {
        color: #f1f1f1
    .sidenav .closebtn {
        position: sticky;
        top: 90%;
        right: 0px;
        font-size: 36px;
        margin-left: 69%
    @media screen and (max-height: 450px) {
        .sidenav {
            padding-top: 15px;
        .sidenav a {
            font-size: 18px;
        .button:hover {
</STYLE>
<script>
    function openNav() {
        document.getElementById("mySidenav").style.width = "250px";
    function closeNav() {
        document.getElementById("mySidenav").style.width = "0";
</script>
<script>
   async function getSoll() {
    response = await fetch("json");
</script>
    setInterval(
        async function sensors() {
        }, 1000);
</script>
<script>
        async function getNodes() {
        let html = '';
        myJson.nodes.forEach(node => {
            html += `<a id="${node.name}" onclick="window.location.href = 'http://${node.ip}'">${node.name}</a>`;})
                document.getElementById('menueList').innerHTML = html;
</script>
        xhr.send();
</script>
        xhr.send();
</script>
        xhr.send();
</script>
    <a id="menueList">1</a>
</div>
        <a> Soll:</a>
        <br>
    </div>
        <a class="button" onclick="submitdown(); getSoll()">-</a>
        <a class="button" onclick="submitup(); getSoll()">+</a>
    </div>
        Aktuell:
        <div>
        </div>
        <div class="hum">
        </div>
    </div>
    <div class="boost">
        <img id="lamp" width="80" height="80" alt>
        <!--*src="Lamp0.svg"-->
    </div>
    <div id="opener">
        <span style="font-size:30px;cursor:pointer" onclick="openNav(); getNodes()">&#9776;</span>
        <span style="font-size:30px;cursor:pointer" onclick="window.location.href = '/tools';">&#8962;</span>
    </div>
</div>
Users browsing this forum: No registered users and 117 guests
