I am able to show dallas sensorvalue in Domoticz
Now I connected LCD to nodemcu
How can I see value of tempsensor on LCD?
-Bart
[Solved] how to display (temp) inputvalue on lcd
Re: how to display (temp) inputvalue on lcd
Most display plugins support some write command, which can be called from the rules.
Some also support some basic string to be set in the task configuration (e.g. the Framed OLED and the OLED plugin support this)
These basic strings also can parse task values.
For example your Dallas sensor is named "dallas" and the temperature value is named "T", then you can use this format:
in the string to write to your display.
This string will then be updated every "Interval" nr of seconds configured in the display task.
[Dallas#T]
Thanks,
For me it worked as follows:
In task of LCD line 1
Aanvoer[temp1#Temperature] C
Whereas temp1 is taskname of Dallas tempsensor.
Bart
Bart
Users browsing this forum: No registered users and 151 guests
