Servus from Munich/Germany
Re: Servus from Munich/Germany
I assume your OLED display utilizes I2C? Maybe there is still a problem if more than one I2C devices are connected and used at the same time. I still have only one I2C device, the BME280, and this works fine.
I have ordered some BH1750 lightsensors. Hope they come today. The BH1750 driver was also on the lib_ignore list because of compiler errors. But there were only some casting issues. When I receive the light sensors I will take them into service together with the BME280 and continue my tests. If this works I could share my BH1750 modification.
I have enabled the software serial because I wanted to minimize the libraries from lib_ignore. Still uninformed for what it is for. Probably this is not the reason why my BME280 seem to work.
I forgot to mention that I have initially also enabled 'SerialSensors' by removing it from the lib_ignore libraries.
Here my current lib_ignore:
lib_ignore = ESP8266WiFi, ESP8266Ping, ESP8266WebServer, ESP8266HTTPUpdateServer, ESP8266mDNS, IRremoteESP8266, ESPEasy_ESP8266Ping
Those software serial lib is for serial communications like the Senseair CO2 sensor and some dust sensors and a few more.
Ok. So, this has also nothing to do with I2C..
Today I got the BH1750 light sensors. And now I understand what you mean with that instabilities.
If I have both (BME280 and BH1750) on I2C bus everything is instable. Sometimes I get values from the lightsensor and sometimes not. Sometimes the web interfaces hangs sporadically.
But when I remove the BME280 electrically and from configuration, the BH1750 seems to run stable.
So, from my current point of view it's problematic to have more than one sensor on one bus. That can cause troubles.
@TD-er: Have you added pullup resistors to your I2C lines? I'm currently not. I need to repeat my tests with pullups.
Yep, there are pull-up resistors present.
There is already a patch present for the I2C problems, but the current implementation may break present libraries using I2c.
I am currently looking into creating a specific PlatformIO platform, so we can use that to make the builds possible for anyone.
Other approach may be to create a pre-compile script to patch the sources of the used PlatformIO platform.
The main problem to me is that currently it is hard to make sure the platform is built again with patched sources.
It is like the Puya patches all over again.
Ok, I undestand.
Let me know, if I could support you with testing. Until now I'm not very experienced with git collaboration (using github). In my company we had our local/private and not web-based git environment.
Then I have ordered yesterday a SSD1306 display. Maybe it's not wrong to have something to display.... Although I have some IL9341 color displays. But they probably need too much RAM for the framing.
Btw, now I have also pull-up resistors. It works a lot more better now. But sometimes it hangs and the module is not sending values to ThingSpeak. Or values are accidentally completely wrong.
Now I have a OLED display and have the same effects like you, TD-er. The display works fine alone. As well as the BME280. But together there is no chance. The display will not be updated anymore after the BME280 was tried to be accessed. With BME280 + BH1750 together the problems was not so heavy.
Could you please give me a hint with the I2C patch you have mentioned? Probably I could try it in parallel. Thank you in advance.
You could try this fork: https://github.com/stickbreaker/arduino-esp32
It looks like it is being merged with arduino-esp32, since this branch has already been merged with the dev branch of them.
But as I understood, it will break the current implementation of the Wire class, so they may need some work to get it right.
Thank you. I will have a look on it tomorrow.
@TD-er: So, I have done a quick test and it looks very promising.
To get fast results I have done the following quick&dirty test by replacing the following 5 files from the stickbreaker fork you have mentioned in the framework tree (in my case framework-arduinoespressif32@1.4.0) in my .platformio folder:
\cores\esp32\esp32-hal-i2c.c
\cores\esp32\esp32-hal-i2c.h
\cores\esp32\esp32-hal-log.h
\libraries\Wire\src\Wire.cpp
\libraries\Wire\src\Wire.h
For ESP32 no further adaptions were needed. Currently I have only a ESP32 build.
And now I can display the BME280 values in the SSD1306 display. And the values are updates correctly within the configured time. Seems to work very stable since 1h (with 20 second update time).
I will do some further tests now with an 3rd I2C device (BH1750) on the bus.
With the 3rd I2C device (BH1750) it still seems to be ok. I get reasonable values from the two sensors and they will be displayed on the OLED display.
Btw, I've observed strange behavior when deepsleep is enabled. Sometimes my ESP32 doesn't wake up properly respectively it doesn't connect to my wifi network. In this state it cannot be accessed anymore and I have erased and reprogrammed the flash. Therefore for the moment my both ESP32 boards + sensors are running without deepsleep.
An other strange effect is, that the web page for ThingSpeak controller configuration is very slow and hangs very often. But with deactived I2C devices there is not difference. So, this is probably caused by something else.
Good to hear the stickbreaker patch is working.
I have had not so much time to work on ESPeasy last few days.
One of the things taking a lot of time was changing my living room, to make a proper dev-corner for me to work on ESPeasy
So I hope to be able to start dev'ing again very soon.
I'm currently on holidays and have also not much time for developing. But my environment is still running stable (with 3 I2C devices). So, the patch seems to fix the problems (for me).
