RFLink R47 available
Information and news about RFLink development and releases
Stuntteam
Site Beheer
#1 Post by Stuntteam » 15 Sep 2017, 17:42
The new RFLink firmware has been released!!
R47: (15/09/2017)
- New Device: Micro Tybox X2D / Tybox H X2D Thermostats (works with 433 and/or 868 mhz)
- New Device: Tybox 310 X2D Thermostat (868mhz)
- New Device: Delta Dore - Deltia 8.03 X2D Thermostat (868mhz)
- New Device: TYXIA 261/461 X2D micro modules (868mhz) (Receive only, more logs needed)
- New Device: Milight RGB+CCT (a.o. 4-zone FUT092/ 8-zone FUT089)
- New Device: Milight RGB (a.o. FUT098)
- New Device: Bofu motor BF-301, EY1612, EY1624 and others
- New Device: Oregon Scientific SL109
- New Device: AR53002 / AR50055 X2D Thermostats
- New Device: Atlantic MD-210R / Focus MD-210R - 868mhz door contact
- New Device: Legrand CAD Radio
- New Device: Gelia EMW100T switch set
- New Device: ELEC EDB-40 / QH-1085TX V1.1 Quhwa doorbell
- New Device: X10 Sensors
- New Device: Ambient FT004T temperature sensor
- New Device: Ambient FT004B temperature sensor
- New Device: ASA radio technology Go-1
- New Device: Telis 4 Modulis RTS
- New Device: Added support for a new version of the Rubicson WT0122 pool thermometer
- New Device: Renkforce E0190TA and compatible temperature sensors
- New Device: Ematronic AC114-01B shutter/blinds controller
- New Device: Yooda Melody shutter/blinds controller
- New Device: Viking 02813 Temperature sensor
- New Device: Marquant 943134 Temperature sensor
- New Device: Arlec RC10 switch set
- New Device: V2 Phoenix remote signals (Receive only)
- New Device: IDK CAR-200 doorbell (Receive only)
- New Feature: GPIO pin state at boot can be selected with a wire from pin 5 to ground to set the pin default to high
- Added: X2D/X3D protocol support
- Added: Milight RGB and RGB+CCT protocol support
- Added: Direct dimming support for Flamingo and compatible devices
- Added: Additional WH3 detection
- Added: Two Additional Dooya protocol flavors
- Added: Additional Dooya signal recognition
- Added: Additional Blyss remote control recognition
- Added: Additional Brell remote control recognition
- Added: STOP command support to (first) extended RTS protocol version
- Added: Support for second extended RTS protocol version
- Added: Additional Pair option for Bofu motor devices
- Added: upon request added 6 additional GPIO pin's for generic use
The GPIO pins are often used to 'press buttons' on incompatible devices
- Fixed: Added pairing command for Ansluta
- Fixed: Increased transmission duration for Ansluta
- Fixed: corrected barometric pressure value of BTHR918
- Fixed: UPM Esic negative temperatures
- Fixed: Further improved X10 protocol detection
- Fixed: 'newkaku' send command handling improved
- Fixed: 'newkaku' group commands put at a unique switch number
- Fixed: imrpoved newkaku filtering
- Fixed: improved Acurite SL109 negative temperature handling
- Fixed: CM113 ampere precision
- Fixed: Milight: bug in unit selection
- Fixed: bug with the number of RFCustom records
- Fixed: removal of RFCustom records
- Fixed: Improved Xiron sensor detection
- Fixed: Alecto rain meter values
www.rflink.nl
jjansen
Re: RFLink R47 available
#2 Post by jjansen » 15 Sep 2017, 19:41
Thank you! Updated and up and running :)
AndrewJ
#3 Post by AndrewJ » 15 Sep 2017, 22:26
A most impressive list of improvements and additions!
bilbolodz
#4 Post by bilbolodz » 09 Oct 2017, 12:50
Could someone point me to page with description of "generic GPIO usage"? Which Arduino pins etc.
bilbolodz
#5 Post by bilbolodz » 31 Oct 2017, 14:19
It looks that " 6 additional GPIO pin's" are OUTPUT pins number 34 to 39. In my case more useful would be INPUT pins. Maybe it's good idea to add (also) more input on free Arduino pins or make already used pins configurable as input/output?
Stuntteam
Site Beheer
#6 Post by Stuntteam » 31 Oct 2017, 15:35
GPIO details here:
http://www.rflink.nl/blog2/faq#GPIO
I will see what I can do with input/ouputs..
